OpenFOAM 2.3 -> OpenFOAM 5.0 Changes in pressure/energy coupling
Old   April 26, 2018, 17:00
Default OpenFOAM 2.3 -> OpenFOAM 5.0 Changes in pressure/energy coupling
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello everyone,
Long time no see. I've been working up updating my organization to OpenFOAM 5.0, and in testing some code I've noticed differences in the pressure/temperature results from cases with moving meshes. The tutorial case for engineFoam is an example I can point to. Plotting the logfiles with pressure and temperature, the new pressure is overpredicting while the temperature is underpredicting. Some testing seems to indicate that the layered engine mesh has something to do with it, but I can't be sure.
Has anyone dealt with this before?
mturcios777 is offline   Reply With Quote
Old   May 4, 2018, 12:24
Marco A. Turcios
Digging deeper, it seems this is a machine/compiler specific error and should be ignored until I can provide more detail.
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer wildfire230 OpenFOAM Installation 20 May 6, 2020 07:30
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 5, 2018 23:48
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
[Salome] hdf file example --> Internal faces Salome --> OpenFOAM student666 OpenFOAM Meshing & Mesh Conversion 1 December 7, 2013 10:09
