Forcecoeffs Cd = Total or skin
Like Tree3Likes
  • 1 Post By tomf
  • 1 Post By tomf
  • 1 Post By tomf
Old   April 16, 2018, 04:42
Default Forcecoeffs Cd = Total or skin
kaaja is on a distinguished road
H
The Cd that is produced by "forceCoeffs", is the coefficient for total drag (both skin and pressure) or only skin-friction?
kaaja is offline   Reply With Quote
Old   April 17, 2018, 08:19
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
In principle total, but the description on openfoam.com would indicate that the viscous, pressure and porous parts can be obtained separately as well.
This is not found in the openfoam.org description. So it depends on what version you are using.
Regards,
Tom
kaaja likes this.
tomf is offline   Reply With Quote
Old   April 17, 2018, 09:41
Thanks for replying!
I use openFoam 5.0.
The variable name I get out is Cd, which I guess indicates that it is total, but I am not sure.
edit: I am using openfoam.org's version, so I guess it is total then?
Old   April 17, 2018, 11:26
Tom Fahner
Yes it is.
Regards,
Tom
kaaja likes this.
Old   April 17, 2018, 13:51
Ok.
Thank you very much for helping!
Another question.
Do you know if there is some way to obtain the viscous, pressure and porous parts separately in the openfoam.org version?
Old   April 18, 2018, 03:51
Tom Fahner
Yes, if you use the forces functionObject. That will split it directly in several force and moment vectors in Cartesian coordinates. You would have to get the coefficients yourself based on the correct direction, surface area and velocity reference.
Regards,
Tom
kaaja likes this.
Old   April 18, 2018, 04:25
Ok. Thanks again!
forcecoeffs
Segmentation fault (core dumped) zhoubiao1088 OpenFOAM Running, Solving & CFD 4 March 13, 2017 20:06
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
total mass loss/gain--simulating taylor couette flow nwpukaka OpenFOAM Programming & Development 0 February 12, 2014 18:57
Error in run Batch file saba1366 CFX 4 February 10, 2013 01:15
