Problem with using oscillatingFixedvalue in OpenFoam 1.6
Old   January 25, 2010, 18:08
Default Problem with using oscillatingFixedvalue in OpenFoam 1.6
markong is on a distinguished road
I tried to follow the OpenFoam wiki to set up the oscillating wall for my simulation, and i changed the refValue from uniform (1 0 0) to uniform (0 0 0), as i want to set up a pure oscillatory flow. It is described as below:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
movingwall
type oscillatingFixedValue;
refValue uniform (0 0 0);
amplitude 1;
frequency 1.257;
fixedWalls
type fixedValue;
value uniform (0 0 0);
However, it doesn't work. The moving wall velocity is always zero. If i set the refvalue to be uniform(1 0 0). The movingwall velocity will start to vary. May i know how i can solve this problem?
Please advise, thanks
markong is offline   Reply With Quote
Old   September 6, 2010, 12:05
Pavan
rieuk is on a distinguished road
can somebody please explain the operation of this boundary condition. What direction is the oscillation enforced
rieuk is offline   Reply With Quote
Old   September 16, 2010, 06:05
Pavan
Ok so I just realised this BC is for scalars and not vectors. Does anyone have any implementation of this BC for vectors??
Old   November 5, 2020, 02:56
Rmc
RMC1 is on a distinguished road
hello, i have the same problem. How did you solve it?
thanks in advance
RMC1 is offline   Reply With Quote
Compilation error for openfoam - 1.6 misakagan OpenFOAM 19 February 21, 2012 10:36
Installing OpenFOAM 1.6 on ubuntu 9.10 nabeels OpenFOAM Installation 32 May 10, 2010 03:09
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 09:04
Problem on Installing OpenFOAM 1.6 on Fedora 11 lzgwhy OpenFOAM Installation 1 August 25, 2009 11:02
