[Sponsors] | |||||
What is the easiest way to create a 2D blockMesh with a triangular cut-out? |
Axel
Rep Power: 11 ![]() |
Hi everybody!
I am trying to get a rather simple 2D mesh, that is basically a rectangular 2D fluid domain with a triangular cut-out in the middle of it, where I can easily change the coordinates of the triangle's points. How can I create such a mesh? I thought about using a topoSet but I couldn't find an option for triangular sets there. Best regards, Axel |
Rep Power: 17 ![]() |
Not sure if this is what you are looking for, but you could use a variable at the top of blockMeshDict for the location of the points of the triangle to conveniently change the geometry of the triangle quickly. If the size of the rectangle is also depending on the triangle it is also possible to make their location dependent on the triangle size etc.
Axel
Hi Bazinga,
thanks for your reply! Yes this is part of the solution I am looking for. However right now I was not even able to get a blockMesh for 3 fixed points. So first I would need some advice on how to get the cut-out with a fixed triangle, then I would take your advice to use the variables in blockMeshDict. Best regards, Axel |
I did not try a triangle yet, but blockMesh should be capable of doing it as you can create blocks with fewer than 8 vertices (check in the user guide "5.3.5 Creating blocks with fewer than 8 vertices").
Axel
Ok, but how would I use the triangle blockMesh to make a cut-out inside a rectangular blockMesh?
Gerhard Holzinger
Rep Power: 29 ![]() ![]() |
Go the extra mile, if you're blockMesh-masochistic enough.
In that case, you can use moveMesh to rotate the red mesh region into any orientation you like. Afterwards, use AMI or stitchMesh to create single mesh region. |
Is this maybe working? (see attachement)
Axel
Hello Gerhard,
this is not exactly what I need as I believe in your case the shape of the triangle would be fixed, right? Best regards, Axel |
#9 |
Axel
Hi Bazinga!
That looks very promising! I will try something like this as soon as I come home. Best regards, Axel |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [Tutorials] Tutorial of how to plot residuals ! | anon_r | OpenFOAM Community Contributions | 172 | December 6, 2024 07:20 |
| Thin Walls using blockMesh | varun | OpenFOAM Running, Solving & CFD | 6 | December 8, 2020 14:18 |
| Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 15:18 |
| fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
| [Technical] What is the best option for create a mesh not using blockmesh | titio | OpenFOAM Meshing & Mesh Conversion | 4 | January 17, 2008 03:37 |
