Best FOAM Workflow
Old   August 19, 2018, 18:40
Default Best FOAM Workflow
E
Jikst is on a distinguished road
I am new and the problem I'm running into is that there seems to be no one optimal workflow for OF.
Seems like everyone's using a mixture of FreeCAD, Sketchup, Salome, Salome Meca, Gmsh, Helyx OS, OnShape, Blender and so forth
My question is What is the optimal free software/workflow for OpenFoam?
Is Salome or Blender powerful enough to create complex CAD or should I use OnShape then Salome to watertight geometry then move to Gmsh for better mesh. Should I start my case with free version of Helyx then edit it from there. guess I'm looking for the best way to do this so I don't waste time fiddling with all these different software's.
Jikst is offline   Reply With Quote
Old   August 27, 2018, 09:42
Elvis
elvis will become famous soon enough
InsightCAE - Open Source Project for Workflow Automation
DICE - OpenFOAM GUI project
alternative mesher
cfMesh library can be downloaded from: https://sourceforge.net/projects/cfmesh/
elvis is offline   Reply With Quote
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
