Solver "command not found" error
Like Tree2Likes
  • 1 Post By kilroy
  • 1 Post By Lieven
Old   April 26, 2013, 17:57
Default Solver "command not found" error
kilroy's Avatar
kilroy is on a distinguished road
I am not an expert on Linux and I am trying to compile "waveFoam" and "waveDyMFoam" solvers. I compiled the "waveFoam" solver successfully. Everything was ready for the "waveFoam" solver, I just downloaded all the files and ran the "Allwmake".
For the "waveDyMFoam" solver I followed the steps described in the wiki below:
https://sites.google.com/site/jordim...ic-mesh-motion
Basically, I modified "waveDyMFoam' from the "interDyMFoam" solver. Everything compiled fine but now when I try to run the "waveDyMFoam" solver, I get the error below:
waveDyMFoam: command not found
I am not sure what did I do wrong. I did everything exactly as described in the wiki. Maybe I should modify another file (bashrc??).
Thank you very much for your time and help,
Kilroy
Kummi likes this.
kilroy is offline   Reply With Quote
Old   April 27, 2013, 03:44
T. Chourushi
Tushar@cfd is on a distinguished road
Kilroy
Your error lies in the application/solver folder.
You don't have to change anything in "bashrc". /.bashrc, is used to set the environmental variable only.
Few doubts:
1. Is your waveFoam command running? If yes, then do check the "/make" folder, may be you have missed some point. May be the path of "/folders" are different in your case then the mentioned case on the weblink.
2. Have you named your file as "waveDyMFoam.C" instead of "interDyMFoam"?
3. Otherwise, try uploading your case here. Will let you know.
Tushar@cfd is offline   Reply With Quote
Old   April 27, 2013, 06:38
Lieven
Lieven will become famous soon enough
An other cause could simply be that the files are created but put in the wrong place.
Check whether the Make/files folder is something like
waveFoam.C
EXE = $(FOAM_USER_APPBIN)/waveFoam
Only the custom solvers put in $(FOAM_USER_APPBIN) are found automatically.
Make sure you compile the solvers with 'wmake' and not 'wmake libso' since this will not work either.
If non of the above is the cause, first try to find the waveFoam solver file by running
sudo updatedb && locate waveFoam
This should autoput a whole list of files and one of them should end with .../bin/waveFoam
Cheers,
Lieven
Lieven is offline   Reply With Quote
Old   April 29, 2013, 10:06
kilroy's Avatar
@Tushar,
Thank you very much for your response. I answered your questions below:
My waveFoam is working but waveDyMFoam is not. I also checked the "/make" folder, it looks exactly the same as described in the weblink.
The path described in the weblink is below:
$WM_PROJECT_USER_DIR/applications/solvers/waves2Foam/applications/solvers/solvers17/waveFoam/waveDyMFoam
And my path is below:
opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam
Yes, I double checked that too.
I uploaded everything in the waves2Foam folder, it is located in the path below:
The link to the case is below:
http://www.filedropper.com/wavedymfoamtar
Old   April 29, 2013, 10:17
kilroy's Avatar
@Lieven,
Thank you very much for your response. My "waveFoam" command is running but "waveDyMFoam" is not.
waveFoam.C
I checked "Make/files" folder for "waveDyMFoam". It looks like below:
waveDyMFoam.C
EXE = $(FOAM_USER_APPBIN)/waveDyMFoam
I compiled the "waveDyMFoam" solver with "wmake".
After I run the command you mentioned above, I can see a line ending with
.../bin/waveFoam
The whole list of files I get, after I run the commands is below:
meta@meta-5:/opt/openfoam220/applications/solvers$ sudo updatedb && locate waveDyMFoam
/home/meta/OpenFOAM/root-2.2.0/platforms/linux64GccDPOpt/bin/waveDyMFoam
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/correctPhi.H
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/pEqn.H
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/readControls.H
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/waveDyMFoam.C
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/waveDyMFoam.C~
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/waveDyMFoam.dep
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/files
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/files~
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/options
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/options~
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/dependencies
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/dependencyFiles
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/dontIncludeDeps
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/files
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/filesMacros
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/includeDeps
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/localObjectFiles
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/objectFiles
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/options
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/sourceFiles
/opt/openfoam211/applications/solvers/waves2Foam/applications/solvers/solvers211/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/waveDyMFoam.o
/opt/openfoam220/applications/solvers/waveDyMFoam.tar.gz
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/correctPhi.H
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/pEqn.H
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/readControls.H
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/waveDyMFoam.C
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/waveDyMFoam.C~
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/waveDyMFoam.dep
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/files
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/options
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/dependencies
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/dependencyFiles
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/dontIncludeDeps
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/files
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/filesMacros
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/includeDeps
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/localObjectFiles
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/objectFiles
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/options
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/sourceFiles
/opt/openfoam220/applications/solvers/waves2Foam/applications/solvers/solvers220/waveFoam/waveDyMFoam/Make/linux64GccDPOpt/waveDyMFoam.o
Old   April 29, 2013, 10:57
Lieven
Ok, this is the line which I was talking about
It looks a bit messed up to me. What I would expect is something like
/home/$username/OpenFOAM/$username-2.2.0/platforms/...
and certainly not 'root' since you should not be working as root. If you open a new terminal and type
echo $FOAM_USER_APPBIN
it will say which folder will be read as regular user. This is where your file waveDynFoam should end up (and I'm pretty sure it will not be the folder from the current list). As I see it, you have 2 options.
1. (recommended) Move all your custom solvers to a folder which you have read and write access to as a regular user (e.g. mine are simply in $home/OpenFOAM/applications) and recompile everything.
2. change the ownership of the /opt/openfoam220 -folder so you can access and modify it as a regular user by typing (change $user in your real user name)
chown -R $user::$user /opt/openfoam220/
and recompile all your custom code again but as regular user (so don't dare to use sudo ;-)).
alia likes this.
Old   April 29, 2013, 11:05
kilroy's Avatar
Lieven,
I think I now why did that happen. At first when I tried to run "wmake" it didn't let me. So first I ran the command "sudo bash", then I ran "wmake". I think that's why everything is so messed up right now.
Now when I open a new terminal and run "sudo bash" first, then the "waveDyMFoam" runs.
But I will fix everything with your first recommendation below:
Thank you very much for your time and help.
Kilroy.
Old   April 29, 2013, 11:15
Lieven
You're very welcome.
This is indeed what I expected
Old   April 30, 2013, 06:25
Smile
T. Chourushi
Lieven,
Kilroy.
Sorry, couldn't able to reply your post. Anyways, Lieven answered your queries.
It's always preferable to install in root directory. As you don't need to call sudo bash when you run your solver.
Or, try giving permission (read and write access) to the user directory
Old   April 30, 2013, 10:04
kilroy's Avatar
Tushar, thank you very much for your time and help.
I am still learning how to use Linux and this case is a very good experience for me to how to work with the environment.
Old   August 30, 2018, 04:56
Default waveFoam not working
  #11
Kazakis Ioannis
Giannis_Kaz is on a distinguished road
Dear friends
I would be grateful if you could help with the above issue. I 've installed and compiled successfully (as it's seems to be done), waves2Foam across openFoam 4.0. I ve also done this, using openFoam 2.4.0 and 3.0.1. Everything seems to be ok when I m running a case, e.g bejiBattjes, except the solver wavefoam. In the log file i took back this message: /opt/openfoam4/bin/tools/RunFunctions: line 93: waveFoam: command not found. I tried a lot of thinks but still not working. I'm asking for your help
Kind Regards
John
Giannis_Kaz is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
