Adjust write interval for function output
Old   September 27, 2018, 00:21
Default Adjust write interval for function output
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
hello foamers
I am running unsteady simulation and output some surface (isosurface of pressure with k,U) with setting functions in controlDict. I set the output as adjustableRuntime in the function with writeInterval with value say 0.1sec, I am trying to change the value to 0.05. But it doesn’t work. I already set the runTimeModifable to yes in the controlDict so that I can change output interval for fields and Co number. Can anybody helps on the that?
Yours Wei
waynezw0618 is offline   Reply With Quote
Old   September 27, 2018, 01:54
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Please provide a test case as well as the FOAM version you are using.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Write interval not in exact number cwang5 OpenFOAM Bugs 8 August 31, 2018 13:26
Execution time problem after first write interval sean_mcintyre OpenFOAM Running, Solving & CFD 3 July 28, 2008 08:46
[Other] Output Format of MetaMesh t42 OpenFOAM Meshing & Mesh Conversion 0 August 3, 2007 04:28
advanced output huwei CFX 1 March 21, 2001 14:43
