Changing wave theories in the tutorials
Old   August 31, 2018, 18:38
Default Changing wave theories in the tutorials
Hillary Kiptoo
larry k is on a distinguished road
Hi Niels,
Thanks for an excellent waves2Foam toolbox. I have been trying to understand the waveflume tutorial so that I can implement it in my case on Oscillating water column. In this regard my case is best implementable on stokesSecond order theory. Unfortunately, I seem not to be getting the idea of changing it to fit my case as I am getting this message when I run the edited waveflume tutorial.
"Reading g
Reading waveProperties
Constructing: stokesFirstProperties (Used by another wave theory)
Constructing: stokesSecondProperties
Constructing: potentialCurrentProperties
End"
I am not quite sure if this is correct or there is a problem and the case is still running on the stokesFirstProperties.
Kind regards,
larry
larry k is offline   Reply With Quote
Old   September 6, 2018, 17:16
Default Changing wave theories from the tutorials
Hillary Kiptoo
Who can help me get an idea on how to implement wave theories on waves2Foam?
Old   September 28, 2018, 04:28
Default ON the use of waves2Foam other wave theories
zhongzhong
shanjiaogangkoumengfei is on a distinguished road
Hello,Excuse me,i want to ask have you solved this problem? i also met it now
if you solved it,can you tell me? Thank you very much
shanjiaogangkoumengfei is offline   Reply With Quote
Old   October 2, 2018, 02:47
Hillary Kiptoo
Hi, sorry for the late response. I found out that my results were agreeable when I change the wave theory in the waveFlume tutorial however, you must know the limits or the validity of each wave theory otherwise you will be in real problems. Perhaps, you can look at this website http://www.calqlata.com/productpages/00020-help.html or graph by T. Sarpkaya (book) for more insights.
Thanks
Larry K.
Old   October 2, 2018, 05:13
Default on the use of waves2Foam other wave theories
zhongzhong
Thank you very much for your reply in your busy schedule.i seem to understand a lot after looking at the websites and materials you provided.Thank you very much.i wish you a convergence.:d
waves2foam
Linear wave force on a cylinder Pumbam CFX 1 July 16, 2017 02:01
[waves2Foam] Wave damped totally in about 5 meters after wave maker, after making changes to case mmbeik OpenFOAM Community Contributions 3 August 18, 2015 05:56
IHFOAM - Wave generation with moving boundaries Phicau OpenFOAM Verification & Validation 0 May 18, 2015 04:53
Deep Water Wave Generation Problems zx9cp CFX 4 June 16, 2013 06:23
Changing the geometry BC and IC of tutorials hyunchang OpenFOAM Running, Solving & CFD 0 September 11, 2007 12:35
