October 10, 2018, 06:23 |
non-functional cylindricalInletVelocity
Zander Meiring
Rep Power: 7 |
Good day,
I am at a loss to the magnitude of different issues I am getting with openFoam this week. In this case; I am trying to specify a rotating inlet to a 1/8th section of an axial flow fan. I am working in the rotating frame of reference, so would like my inlet velocity to be rotating about the axial direction (y direction in my case). The goal for now is to troubleshoot why my solution is diverging by analyzing a potentialFoam case, so only my U file is of importance. It is set up as such: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 5 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 -10.96 0); boundaryField { inlet { type cylindricalInletVelocity; origin (0 0 0); axis (0 1 0); radialVelocity constant 0; axialVelocity constant -10.96; rpm constant 750; value (0 0 0); } outlet { type zeroGradient; } blade { type fixedValue; value uniform (0 0 0); } left { type cyclicAMI; } right { type cyclicAMI; } shroud { type symmetry; } hub { type symmetry; } } // ************************************************************************* // I'm at a loss for what to do here, so any help would be appreciated. Regards |
coordination Transform -functional object | Chris123 | OpenFOAM Post-Processing | 3 | July 8, 2022 05:07 |
Meaning of flow functional in Vreman SGS model | sjwon1991 | Main CFD Forum | 1 | May 8, 2016 05:22 |
Functional relation between velocity at cell center and flux | fumiya | OpenFOAM | 0 | November 29, 2012 10:59 |
OF15 paraFoam Update GUI not functional | aunola | OpenFOAM Installation | 1 | July 28, 2008 00:32 |
Density functional theory in hydrodynamics | DFT | Main CFD Forum | 0 | July 6, 2004 08:18 |
