Floating Point Error
Old   December 1, 2018, 10:56
Default Floating Point Exception Error
Tejas
rkpk is on a distinguished road
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? at ??:?
#4 ? at ??:?
#5 ? at ??:?
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? at ??:?
Floating point exception (core dumped)
hello everybody i am trying to solve a compressible flow problem with my new solver but it is showing this error.
Can anybody help?
Thank You.
rkpk is offline   Reply With Quote
Old   December 3, 2018, 23:43
tobiasS's Avatar
Hussam
tobiasS is on a distinguished road
Hey Tejas,
Please read follow the instruction in the link, to get the help. It's impossible to tell the problem only with the information you've delivered.
Cheers!
Hussam
How to give enough info to get help
tobiasS is offline   Reply With Quote
Old   December 3, 2018, 23:45
tobiasS's Avatar
Hussam
Old   December 4, 2018, 03:38
Robert
RobertHB is on a distinguished road
Originally Posted by rkpk View Post
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#3 ? at ??:?
#4 ? at ??:?
#5 ? at ??:?
#7 ? at ??:?
Can anybody help?
Thank You.
Without knowing your simulation or more of your log before the error occured i can only guess. But be best guess would be: Your Courant number blew up.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
floating point error, openfoam error
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 02:03
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
