July 21, 2011, 04:17 |
Creating arbitrary surfaces in meshed domain
Suhas
Rep Power: 14 |
hi,
Please tell me that how to create arbitrary surfaces (or somthing like that) (other than predefined patches) to calculate area or mass weighted averages of any function for postprocessing in predefined+meshed+solved domain openfoam 1.7.1? thanks in advance Last edited by suh; July 21, 2011 at 04:38. |
July 21, 2011, 19:01 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The library swak4foam (search the board or google) allows you to do calculations on these surfaces (but it builds on the same mechanism, so sampleDict will give you an idea which surfaces are possible) |
July 22, 2011, 08:51 |
Suhas
Rep Power: 14 |
Thank you for replying..
Actually i done with that thing, but problem is that i want to use patchAverage <field> <requiredsurface> , so that i can directly know about mass or area weighted average on that particular surface (not a predefined boundary). but how to get that individual surface from domain to calculate like this that i dont know. or is there any way to calculate area or mass weighted averages on arbitrary surfaces in domain in any postprocessing software coming with openfoam. thank you for your precious time. plz reply.. |
August 5, 2011, 05:33 |
Cedric Van Holsbeke
Rep Power: 16 |
You can use the patchAverage function as a funtionObject on a plane by adding some code to your controlDict. In the following code, an area weighted average of the pressure is calculated every outputTime (when the data is written) on a plane that is given by a base point and a normal vector.
In the sampledSurfaceDict, you can also use other types of planes (see examples in $FOAM_APP/applications/utilities/postProcessing/sampling/sample/sampleDict file) Code:
functions ( new_plane { type faceSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; log true; valueOutput true; source sampledSurface; sampledSurfaceDict { type plane; // always triangulated basePoint (0.0501 0.0501 0.005); normalVector (0.1 0.1 1); } operation areaAverage; fields ( p ); } ) |
August 5, 2011, 08:31 |
Suhas
Rep Power: 14 |
Thank you.
I will try this and let u know. Regards Suhas |
July 4, 2012, 15:56 |
ak
Rep Power: 14 |
Hi Suhas and Cedric,
I tried running the code and got the following error: keyword sourceName is undefined in dictionary Could you please suggest how to get rid of this error? I use OF 1.7.1 The code works when I define source as patch and sourceName as inlet. But I'd like to perform the calculations on an internal plane, within the mesh. Thanks so much, amit |
December 20, 2017, 22:14 |
#7 | |
Bingchuan
Rep Power: 8 |
I am facing the same issue now, Could you please share your experience? Thanks. Bests, Bingchuan |
August 20, 2019, 13:27 |
pressure area average over a plane
Hello all,
I tried the function recommended by CedricVH to obtain the area averaged pressure over a plane and it did not work I want to define a plane in the fluidized bed to obtain the area average pressure over an arbitrary plane either on the fly or at the end of the simulation. I have tried to define a Function object and also tried TopoSet but could not figure it out. Can you please guide me to an example or explain the best approach to do this. I imported the mesh from workbench Ansys and using OpenFOAM v6. Thanks! |
create arbitrary surface |
Importing or Creating 2D Flat Surfaces into CFX | Sam | CFX | 5 | March 30, 2013 11:11 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
CFX - domain decomposition. Urgent!!!! | Elena Saldaeva | CFX | 4 | June 30, 2008 07:18 |
Help with creating a plane in the domain | Tony | CFX | 2 | September 14, 2004 18:12 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
