error: ‘incompressible’ was not declared in this scope
Like Tree2Likes
  • 2 Post By ameya2310
Old   March 11, 2018, 01:55
Default error: ‘incompressible’ was not declared in this scope
Ameya
ameya2310 is on a distinguished road
Hello OF Experts,
I am trying to compile a new solver in openFoam 17.1,
Link to the solver: http://openfoamwiki.net/index.php/Co...nesqSimpleFoam
in the process I encountered following error msg:
Making dependency list for source file massBuoyantBoussinesqSimpleFoam.C
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/TurbulenceModels/incompressible/lnInclude -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/transportModels -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/transportModels/incompressible/singlePhaseTransportModel -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/finiteVolume/lnInclude -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/meshTools/lnInclude -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/sampling/lnInclude -IlnInclude -I. -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/OSspecific/POSIX/lnInclude -fPIC -c massBuoyantBoussinesqSimpleFoam.C -o /home/ameya2310/OpenFOAM-in-Box-17.10/OpenFOAM-dev/platforms/linux64Gcc62DPInt32Opt/applications/solvers/massBuoyantBoussinesqSimpleFoam/massBuoyantBoussinesqSimpleFoam.o
In file included from massBuoyantBoussinesqSimpleFoam.C:61:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:78:13: error: ‘incompressible’ was not declared in this scop
e
autoPtr<incompressible::RASModel> turbulence
createFields.H:78:37: error: template argument 1 is invalid
createFields.H:80:9: error: ‘incompressible’ is not a class, namespace, or enumeration
incompressible::RASModel::New(U, phi, laminarTransport)
Any help is appreciated, Thank You.
File Type: txt modifiedOptionsFile.txt (552 Bytes, 14 views)
yewi and Gang Wang like this.
ameya2310 is offline   Reply With Quote
Old   January 10, 2019, 09:52
Yehezkiel Wiliardy
yewi is on a distinguished road
Hey did you manage to solve the problem? I am having similar situation while compiling this solver.
Cheers.
yewi is offline   Reply With Quote
new solver, openfoam 1.7.0, options, wmake problems
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
