Premixed gas explosion in a rectangular chamber |
Abel Tenu
Rep Power: 10 ![]() |
Hello guys,
I need some help. I want to model a premixed gas (hydrogen-air and methane-air) explosion in a rectangular chamber with obstacles at different positions using OpenFOAM for my master thesis. Can someone recommend me which solver (other than XiFoam) I have to use? One the other thing is that one end of the chamber is closed with PVC membrane which will break at low pressure (i.e it will be open), allowing the high-pressure gases (both unburned and burned) to escape. Which boundary condition I have to use? Thank you |
Rep Power: 12 ![]() |
Why don't you use xiFoam?
The outlet boundary is tricky to model exactly. Which field boundary you are concerned with, pressure or velocity? There is wavetransmissive boundary condition. https://openfoamwiki.net/index.php/H...dary_condition |
Abel Tenu
Hi Uyan,
Thank you for your replay. I just want to try if there is another solver than XiFoam, but now I decided to use it. I am mainly focused on the overpressure and flame propagation speed. I am using wavetransmissive boundary condition for the pressure field. I think that it only allows the pressure wave propagating through the boundary, but I also want the flame to propagate through the boundary and escape from the chamber. Is there a boundary condition to do that? One of my cases is a hydrogen-air explosion, how can I get the Gulder Coefficients for Hydrogen? |
#4 | |
In the tutorial case there is a case for hydrogen air mixture, which uses a different flame speed correlation. |
Abel Tenu
Hi Uyan,
Is it possible to use reactingFoam for premixed combustion? Thank you |
Tobias Holzmann
Rep Power: 51 ![]() ![]() ![]() |
Hi all,
I am also interested in such simulations. So if you get any further news, please share it with the community. Do you know any literature about the Xi model approach? I am only familiar with the flamelet model. Thanks in advance.
Keep foaming, Tobias Holzmann |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
combustion model in premixed combustion chamber | wuyu | FLUENT | 9 | February 16, 2018 10:40 |
Having problems setting up boundary conditions for paint chamber simulation | shigua | FLUENT | 0 | December 3, 2014 10:26 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
