--> FOAM FATAL IO ERROR: Unknown patchField type patch for patch type patch |
March 4, 2019, 03:23 |
aiman al-haddad
hello people, I'm new to Openfoam..
when I try to run the simpleFoam, this error appeared. can someone tell me the error/problem ? and also how to fixed it. Thank you Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 1000 steps. Reading field p Reading field U --> FOAM FATAL IO ERROR: Unknown patchField type patch for patch type patch Valid patchField types are : 76 ( SRFFreestreamVelocity SRFVelocity activeBaffleVelocity activePressureForceBaffleVelocity advective atmBoundaryLayerInletVelocity calculated codedFixedValue codedMixed cyclic cyclicACMI cyclicAMI cyclicSlip cylindricalInletVelocity directionMixed empty externalCoupled fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedNormalInletOutletVelocity fixedNormalSlip fixedShearStress fixedValue flowRateInletVelocity fluxCorrectedVelocity freestream inletOutlet interstitialInletVelocity kqRWallFunction mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mappedFlowRate mappedVelocityFlux mixed movingWallVelocity nonuniformTransformCyclic oscillatingFixedValue outletInlet outletMappedUniformInlet outletPhaseMeanVelocity partialSlip pressureDirectedInletOutletVelocity pressureDirectedInletVelocity pressureInletOutletParSlipVelocity pressureInletOutletVelocity pressureInletUniformVelocity pressureInletVelocity pressureNormalInletOutletVelocity processor processorCyclic rotatingPressureInletOutletVelocity rotatingWallVelocity sliced slip supersonicFreestream surfaceNormalFixedValue swirlFlowRateInletVelocity symmetry symmetryPlane timeVaryingMappedFixedValue translatingWallVelocity turbulentInlet uniformFixedGradient uniformFixedValue uniformInletOutlet uniformJump uniformJumpAMI variableHeightFlowRateInletVelocity waveTransmissive wedge zeroGradient ) file: /home/yophaddad/openfoam30/yophaddad/0/U.boundaryField.inlet from line 26 to line 26. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 143. FOAM exiting |
March 4, 2019, 04:20 |
Rep Power: 8 |
Hi haddad,
there is a problem in your U file in line 26. I think that you are not using one of the valid patchField types. If you need more help please post the U file. But please have a look at this before: How to give enough info to get help Kind regards, Krapf |
simplefoam, simplefoam convergence |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 11:36 |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
rhoPimpleFoam hardship | petrus | OpenFOAM Running, Solving & CFD | 0 | October 7, 2016 02:41 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
