How to see/visualize tip vortices in OpenFoam/Paraview
Like Tree2Likes
  • 1 Post By Krao
  • 1 Post By Carlo_P
Old   October 16, 2019, 02:02
Default How to see/visualize tip vortices in OpenFoam/Paraview
chandra shekhar pant
chandra shekhar pant is on a distinguished road
Dear Foamers,
I have a 3D blade and a propeller kind of setup (a rotor and 3 blades), I want to see the tip vortices in both of them. As of now I have no idea about that. Any suggestion will be very helpful.
For the blade the flow is in +y direction and for the propeller set up the flow is in -ve y direction (in figure into the plane). For the blade y is horizontal and z is vertical.
Hoping to get some help. Thanks!
chandra shekhar pant is offline   Reply With Quote
Old   October 16, 2019, 04:07
Kmeti Rao
Krao is on a distinguished road
Chandra Shekar, please go through this video they have covered many post processing topics. https://www.youtube.com/watch?v=ZxJnOB0Gwn8
faiazk likes this.
Krao is offline   Reply With Quote
Old   October 16, 2019, 09:25
hxaxtma is on a distinguished road
- Either use streamlines and tube filter for visualization
- Or calculate vortex criteria (vorticity, Lambda2, Q-criterion) at a certain isovalue or threshold.
- for restricting to the tip clip the scene to your area of interest
hxaxtma is offline   Reply With Quote
Old   October 16, 2019, 10:36
Thanks for your reply, but no, this is not helping me. Please find the overall set up of my computational domain herewith. In this I have to see/visualize the 3D flow, tip vortex etc. I think I made the computations correct but I am not finding a way to visualize it. As you can see if I slice around z then it becomes an aerofoil and flow is from +ve y direction, if I slice it around x then flow is from left to right. Actually I wanted a slice in z direction to show the aerofoil and the flow in y (streamwise) and z direction. I don't know if I am clear with the question or not. However looking a velocity contours, it seems that I am there are indeed some tip vortices etc, but unfortunately I am not able to see it explicitly. Any help is highly welcomed !
Thanks again !
Old   October 16, 2019, 10:45
OK, at this point you should look for some basic paraview tutorials. I am sorry, but all this slicing is really confusing me ;-)
In the end, a tip vortex is 3D, so try to keep your visualizations 3D.
Old   October 17, 2019, 02:18
That's the main problem. How to visualize in 3D ? Could you please suggest some videos/pdf etc in this regard. I have really no idea how to visualize flow/vortex in 3D? Because what I understand from the pdf/video is that the inside of the domain can be visualized by wire-frame option, however if I on this with the internal Mesh on, nothing worth can be seen. Please help in this regard.
Thanks !
Old   October 17, 2019, 03:09
Please provide your setup on google drive. It is more easy for me just creating a paraview state file where you can follow the pipeline....
Old   October 17, 2019, 03:41
Many thanks for the help, the set up means the folders of system, constant and 0.orig ? The size is about 3 GB..How to share it in google drive? Please share your gmail id etc. Sorry, but I don't know the other way of sharing? Thanks for the help again!
Old   October 17, 2019, 04:06
Carlo_P
Carlo_P is on a distinguished road
Chandra,
as folder, one need only constant/polymesh and the last iteration folder and better the system folder.
Please, you can remove the stl file from constant/trimesh and the different folder for the processor.
3 GB seems to be a little to big, if you remove the stl file and all the time step expect the last one.
Cheers!
amolrajan likes this.
Carlo_P is offline   Reply With Quote
Old   October 17, 2019, 09:55
Ok, thanks for the help and looks interesting. Sorry the file size is about 6 GB, how to share this? Please share your gmail id, or any thing site through which it can be shared.
Thanks!
Old   October 17, 2019, 10:04
Sorry for multiple replies, but after zipping it becomes 1.5 GB.
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
Wing Tip Vortices dfitz1000 FLUENT 9 May 16, 2016 11:19
Validating a paper on wing tip vortices holy FLUENT 4 May 3, 2012 06:20
Displaying wing tip vortices andyjo22 ANSYS 0 April 5, 2012 18:55
Wing tip vortices using Fluent Jainy FLUENT 3 August 22, 2005 19:13
