March 25, 2019, 03:58 |
OpenfOAM Average over a line
Manaf Muhammed
Rep Power: 7 |
Hi
Can anybody please tell me how to take the average of velocity or any property across a line in OpenFOAM. The average across a plane can be taken using faceSource function, but how can i take the average across a line. A similar discussion in the forum explains how to get it using paraview using two cutplanes, but is there a way to get it in openfoam. Also if it is possible how can i do it as a runtime post processing? Please help Thanking you |
March 28, 2019, 15:21 |
Rep Power: 14 |
Yes, it is straightforward. You can use the sample utility (postProcess -func sample) to sample on the line for times you have written output. Then post process in a program of your choice to average the sets of data.
Caelan |
March 29, 2019, 03:36 |
Manaf Muhammed
Rep Power: 7 |
thankyou sir
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
