Accessing Coefficient Matrix
Like Tree9Likes
  • 6 Post By fumiya
  • 1 Post By fumiya
  • 1 Post By EmadTandis
  • 1 Post By santiagomarquezd
Old   January 14, 2013, 14:41
Default Accessing Coefficient Matrix
hawkeye321 is an unknown quantity at this point
Hi FOAMERS
I am trying to access to elements of the coefficient matrix of an equation using lduAddresing
Foloowing the procedure in "OpenFOAM guide/Matrices in OpenFOAM" http://openfoamwiki.net/index.php/Matrices_in_OpenFOAM
I use
scalarField *lowerPtr_;
scalarField *diagPtr_;
scalarField *upperPtr_;
for (register label face=0; face<l.size(); face++)
Diag[l[face]] -= Lower[face];
Diag[u[face]] -= Upper[face];
But I get the following errors
error: ‘l’ was not declared in this scope
error: ‘Diag’ was not declared in this scope
error: ‘Lower’ was not declared in this scope
error: ‘u’ was not declared in this scope
error: ‘Upper’ was not declared in this scope
Do you have any idea what these errors are?
PS: I have included these header files
#include "fvCFD.H"
#include "wallFvPatch.H"
#include <fstream>
#include <string>
#include <stdio.h>
#include <time.h>
#include <iostream>
hawkeye321 is offline   Reply With Quote
Old   January 14, 2013, 17:58
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
If your equation is UEqn, you can access the diag, upper and lower
coefficients of UEqn in the following manner:
    label Nc = mesh.nCells(); //Total number of cells
    //Diagonal coefficients
    for(label i=0; i<Nc; i++)
        Info<< UEqn.diag()[i] << endl;
    //Off-diagonal coefficients
    for(label faceI=0; faceI<UEqn.lduAddr().lowerAddr().size(); faceI++)
        Info<< UEqn.upper()[faceI] << endl; //Lower coefficients
        Info<< UEqn.lower()[faceI] << endl; //Upper coefficients
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
Old   January 14, 2013, 18:11
Fumiya Thanks for the answer
Would you please also let me know what does "lduAddr()" and "lowerAddr()" mean here?
Old   January 14, 2013, 23:28
fumiya's Avatar
Fumiya Nozaki
Hi mahdiiowa,
I don't understand what exactly "lduAddr()" means,
but you can access the "owner" cell label by UEqn.lduAddr().lowerAddr()[faceI]
and the "neighbour" cell label by UEqn.lduAddr().upperAddr()[faceI], respectively.
Hope that helps,
Fumiya
EmadTandis likes this.
Old   March 6, 2013, 16:35
Yahoo is on a distinguished road
Thanks for the comment.
Yahoo is offline   Reply With Quote
Old   June 1, 2013, 07:11
Emad Tandis
EmadTandis is on a distinguished road
Originally Posted by mahdiiowa View Post
Hi FOAMERS
I use
#include "fvCFD.H"
#include <fstream>
#include <string>
#include <stdio.h>
#include <time.h>
#include <iostream>
Thanks mahdiiowa for your good link
this error is because the Diag, upper, ... is defined as a function in special class (I think lduMatrix or fvMatrix). If you want to call this function, you have to construct object from those class. example:
ldumatrix A
... (Defenition A)
now, you can call A.diag() and A.upper() , ...
I Hope this help you.
best Regards
Emad Tandis
Yahoo likes this.
EmadTandis is offline   Reply With Quote
Old   June 4, 2013, 07:53
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, you can use gdbOF to access the matrix coefficients at debugging time.
Regards.
Yahoo likes this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   April 27, 2019, 06:40
Thang
thang_cegroup is on a distinguished road
We use lduaddressing to access non-zero coefficient matrix. But how about the zero coefficient ? Can we access them too ? I need to change some zero coefficient into non-zero coefficient to implement cyclic bc for block matrix in foam extend 4-0 since the cyclic is not implemented for block matrix ?
Do you guys have any suggest to solve this problem ? Even a few information might help a lot ?
thang_cegroup is offline   Reply With Quote
How the cyclic boundary condition affect the coefficient matrix codinging OpenFOAM Programming & Development 5 October 20, 2015 07:26
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 21:47
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
couldn't allocate fine level coefficient matrix Sasha FLUENT 0 December 1, 2005 15:31
couldn't allocate fine level coefficient matrix Satish Perivilli FLUENT 1 February 14, 2005 16:48
