Get multiple Angles Of Attack Without changing the Mesh ?!!
Old   May 19, 2019, 07:15
Default Get multiple Angles Of Attack Without changing the Mesh ?!!
Os
losiola is on a distinguished road
hello Foamers ,
I am making a 2D airfoil simulation using open Foam and i want to calculate the aerodynamic performnce of the aifoil (Cd,Cl,Cm) for multiple angles of Attack .
How Can i set multiple angles of attack without having to rotate the airfoil and regenerate new mesh for evrytime?
losiola is offline   Reply With Quote
Old   May 19, 2019, 14:35
blackpingu is on a distinguished road
You can change the internal field velocity vector in the 0-folder.
internalField uniform (0 0 0);
alpha=0
internalField uniform (1 0 0);
alpha = 45
internalField uniform (0.70710678118
0.70710678118
0);
blackpingu is offline   Reply With Quote
Old   May 19, 2019, 15:32
Os
alpha=0
alpha = 45
Thank you for the reply , But how about the Boundary conditions that i should use on top bottom and outlet since the flow may go with 45 ° for exemple this means i cant just use the symmetry boundary conditions on top and bottom ?
Old   May 20, 2019, 04:45
You can define it like in the damBreak tutorial:
atmosphere
type pressureInletOutletVelocity;
value uniform (0 0 0);
change the uniform to whatever angle you have
Old   May 20, 2019, 10:25
mzzmrt is on a distinguished road
It's better to make an "O grid" for such a case. So you can define the velocity vector (x, y, z) in u and use the same mesh for all AoA range...
mzzmrt is offline   Reply With Quote
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
