Get multiple Angles Of Attack Without changing the Mesh ?!! |
May 19, 2019, 07:15 |
Os
Rep Power: 8 |
hello Foamers ,
I am making a 2D airfoil simulation using open Foam and i want to calculate the aerodynamic performnce of the aifoil (Cd,Cl,Cm) for multiple angles of Attack . How Can i set multiple angles of attack without having to rotate the airfoil and regenerate new mesh for evrytime? |
May 19, 2019, 14:35 |
#2 | |||
Rep Power: 7 |
You can change the internal field velocity vector in the 0-folder.
May 19, 2019, 15:32 |
#3 | |
Os
Rep Power: 8 |
Thank you for the reply , But how about the Boundary conditions that i should use on top bottom and outlet since the flow may go with 45 ° for exemple this means i cant just use the symmetry boundary conditions on top and bottom ? |
May 20, 2019, 04:45 |
Rep Power: 7 |
You can define it like in the damBreak tutorial:
atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } change the uniform to whatever angle you have |
May 20, 2019, 10:25 |
Rep Power: 12 |
It's better to make an "O grid" for such a case. So you can define the velocity vector (x, y, z) in u and use the same mesh for all AoA range...
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 18:58 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
