Extracting the matrix data from an fvVectorMatrix
Like Tree4Likes
  • 1 Post By stevemoore1981
  • 2 Post By Jesper_Roland
  • 1 Post By Jesper_Roland
Old   February 22, 2016, 05:30
Default Extracting the matrix data from an fvVectorMatrix
Steve Moore
stevemoore1981 is on a distinguished road
Hi
I'm currently trying to modify the pimpleFoam solver to incorporate some optimal control theory into it. In doing so, I'm trying to obtain a matrix that describes the converged solution at each time step... meaning something like A U = b, where U is the converged discrete velocity field at each time step. I was assuming that if the solution has converged at a given time step, then one could create an fvVectorMatrix:
fvVectorMatrix UEqnTest(fvm::ddt(U) + fvm::div(phi,U) == fvm::laplacian(nu,U) - fvc::grad(p));
and then extract the diag, upper, and lower data, and the source term. I was passing this object into a function (along with the converged velocity field):
write("System", runTime.timeIndex(), UEqnTest, U);
at each time step and writing out the matrix data (and source term) into an .m file as a list of {row, col, val} triplets that I could use to create a sparsematrix object in Matlab, solve the linear system there (i.e. U=A\b), and compare to the velocity field written out by OpenFOAM. The write function looks like:
void write(word matrixName, label timeIndex, fvVectorMatrix M, volVectorField& U)
std::stringstream fileName;
char timeStep[8];
sprintf(timeStep, "%05d", timeIndex);
fileName << matrixName << timeStep << ".m";
std::fstream file(fileName.str().c_str(), std::ios:ut);
const scalarField& diag = M.diag();
const vectorField& source = M.source();
const labelUList& neighbor = M.lduAddr().lowerAddr();
const labelUList& owner = M.lduAddr().upperAddr();
const scalarField& lower = M.lower();
const scalarField& upper = M.upper();
file << "Data = [" << std::endl;
for(label i=0; i<diag.size(); i++)
file << i+1 << "\t" << i+1 << "\t" << diag[i] << std::endl;
for(label f=0; f<upper.size(); f++)
file << owner[f]+1 << "\t" << neighbor[f]+1 << "\t" << lower[f] << std::endl;
file << neighbor[f]+1 << "\t" << owner[f]+1 << "\t" << upper[f] << std::endl;
file << "];\n " << matrixName << "Matrix = sparse(Data(:,1), Data(:,2), Data(:,3));\n";
file << "Source = [" << std::endl;
for(label i=0; i<source.size(); i++)
file << i+1 << "\t" << source[i][0] << "\t" << source[i][1] << "\t" << source[i][2] << std::endl;
file << "];\n";
file << "Solution = [" << std::endl;
for(label i=0; i<U.size(); i++)
file << i+1 << "\t" << U[i][0] << "\t" << U[i][1] << "\t" << U[i][2] << std::endl;
file << "];\n";
file.close();
return;
What I've found is that the OpenFOAM solution and the Matlab solution (computing U=A\b for the A and b that I wrote out from this fvVectorMatrix) are similar, but there is a significant difference. I've attached a .pdf plotting the two solutions for the Ux component of the solution for a simple 2D channel flow (generated in blockMesh as a simple rectangular domain, 1 block with 100 x 15 x 1 cells).
My questions essentially boils down to whether I am correct in assembling a system of equations this way (i.e. the fvVectorMatrix object that I construct inside the time marching loop, but after the pimple.loop() while loop) and assuming that solving that system should give me the converged velocity field for that time step?
shizuka likes this.
stevemoore1981 is offline   Reply With Quote
Old   April 16, 2016, 21:49
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
You are not considering the BC's contributions, take a look of this:
https://openfoamwiki.net/index.php/Contrib_gdbOF
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   November 12, 2017, 14:09
piccinini is on a distinguished road
Will that work (with bc contributions) If I export the matrix after solve() is called?
That is, after pEqn.solve() is called in the code bellow?
Thanks is advance.
        fvScalarMatrix pEqn
                    fvm::laplacian(-Mf,p) + fvc::div(phiG)
        pEqn.solve();
piccinini is offline   Reply With Quote
Old   August 25, 2018, 03:51
wei leng
lengweee is on a distinguished road
Thanks a lot for the piece of code to export foam internal matrix to matlab.
I add the boundary matrix output, based on your code, please find in the code below.
Also attached is a simple matlab script to vertify that A * x = b.
The function is based on vector, scalar case is similar.
	   fvVectorMatrix M,
	   volVectorField& U)
    char timeStep[8];
    std::fstream file(fileName.str().c_str(), std::ios::out);
    file.precision(15);
    const unallocLabelList&  neighbor = M.lduAddr().lowerAddr();
    const unallocLabelList&  owner = M.lduAddr().upperAddr();
    file << "];\n";
    file << "];\n";
    file.close();
    // Output Boundary condition
    for (int k = 0; k < 3; k++) {
	char name[1000];
	char surfix[3][100] = {
	    "x", "y", "z"
	sprintf(name, "Bdry%d_%s.m", timeIndex, surfix[k]);
	FILE *fp = fopen(name, "w");
	fprintf(fp, "bc%s = [\n", surfix[k]);
	forAll(M.internalCoeffs(), patchI)
		const label*  fPtr = M.lduAddr().patchAddr(patchI).begin();
		Field<double> intF(M.internalCoeffs()[patchI].component(k));
		Field<double> bouF(M.boundaryCoeffs()[patchI].component(k));
		forAll(M.lduAddr().patchAddr(patchI), faceI)
			label fCell = fPtr[faceI];
			//diag(fCell) -= intF[faceI];
			fprintf(fp, "%5d %30.15e %30.15e\n",
				fCell+1, intF[faceI], bouF[faceI]
	fprintf(fp, "];\n");
	fclose(fp);
    return;
%% Read solution
    UEqn00001;
    Bdry1_x;
    Bdry1_y;
    Bdry1_z;
n=length(Source);
I = Source(:,1);
bx = ones(n,1);
by = bx;
bz = bx;
bx(I) = Source(:,2);
by(I) = Source(:,3);
bz(I) = Source(:,4);
I = Solution(:,1);
ux = ones(n,1);
uy = ux;
uz = ux;
ux(I) = Solution(:,2);
uy(I) = Solution(:,3);
uz(I) = Solution(:,4);
%% Modify with BC
A0 = UEqnMatrix;
% x
A = A0;
fx = bx;
I=bcx(:,1);
for i = 1:length(I)
    A(I(i),I(i)) =  A(I(i),I(i)) + diag(bcx(i,2));
    fx(I(i)) = fx(I(i)) + bcx(i,3);
end
fprintf('resx: %e\n', max(abs(A * ux - fx)));
lengweee is offline   Reply With Quote
Old   March 22, 2019, 20:02
Default fvMesh
-- Country other than USA or Canada --
kkamau is on a distinguished road
I am pretty sure you are interchanging owners with neighbours in the above code. May be that is the source of the error
kkamau is offline   Reply With Quote
Old   October 14, 2020, 11:15
Jesper R. K. Qwist
Jesper_Roland is on a distinguished road
owners and neighbours have been interchanged in code by lengweee.
Reference:
fvMesh.H - Line 375 - 387
//- Internal face owner. Note bypassing virtual mechanism so
// e.g. relaxation always gets done using original addressing
const labelUList& owner() const
return fvMesh::lduAddr().lowerAddr();
//- Internal face neighbour
const labelUList& neighbour() const
return fvMesh::lduAddr().upperAddr();
Alternative solution to extract matrix. Put this code in solver code to extract pressure equation matrix system. You can modify it to work for a vector matrix as well.
const scalarField& diag = p_rghEqn.diag();
IOField<scalar> wdiag
IOobject
"diag",
mesh.time().timeName(),
mesh,
IOobject::NO_READ
diag
const scalarField& upper = p_rghEqn.upper();
IOField<scalar> wupper
IOobject
"upper",
mesh,
IOobject::NO_READ
upper
const scalarField& source = p_rghEqn.source();
IOField<scalar> wsource
IOobject
"source",
mesh,
IOobject::NO_READ
source
// Assigning contribution from BC
forAll(p_rgh.boundaryField(), patchI)
const fvPatch &vfp = p_rgh.boundaryField()[patchI].patch();
forAll(vfp, faceI)
label cellI = vfp.faceCells()[faceI];
wdiag[cellI] += p_rghEqn.internalCoeffs()[patchI][faceI];
wsource[cellI] += p_rghEqn.boundaryCoeffs()[patchI][faceI];
// write to file
wdiag.write();
wsource.write();
wupper.write();
Now you can load the data from the text files into you favourite data processing tool and assemble the matrix and solve it.
dlahaye and MajidHagh like this.
Last edited by Jesper_Roland; October 19, 2020 at 05:16. Reason: Added alternative solution
Jesper_Roland is offline   Reply With Quote
Old   October 19, 2020, 13:12
Domenico Lahaye
dlahaye is on a distinguished road
Wonderful, thanks!
Suppose now targeting the parallel case, i.e., suppose the linear system A u = b to be decomposed into 2 non-overlapping domains such that the vectors can be decomposed as
u = [u_0; u_1], b = [b_0; b_1] and the matrix to be decomposed as
A = [A_{00} A_{01} ; A_{10} A_{11}].
Can u_i, b_i and A_{ij} be printed seperately?
Thanks again. Domenico Lahaye.
dlahaye is offline   Reply With Quote
Old   October 20, 2020, 07:50
Jesper R. K. Qwist
I do not know how it works for parallel computations.
Best,
Jesper
dlahaye likes this.
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
compiling fails: UDF for extracting mixture fraction data Nekrokeks Fluent UDF and Scheme Programming 5 June 22, 2015 07:37
Extracting Raw Data from STARCCM+ rks171 STAR-CCM+ 3 December 30, 2011 17:10
Problems with extracting data Alicelin OpenFOAM Post-Processing 0 January 25, 2010 08:54
Extracting Stream Function from nodal u,v data Abhijit Tilak Main CFD Forum 5 March 8, 2004 16:13
