Unphysical velocity, rotating frame(dbns-> Roe Flux ->Venkatakrishnan limiter) |
November 21, 2019, 01:27 |
Bidesh Sengupta
Rep Power: 7 |
Hi !!
I am giving my checkMesh results with some images of the mesh. Overall domain bounding box (-2.500042546 -2.500042549 -2.5) (2.500042479 2.500042481 2.5) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.694856469e-17 3.009640066e-17 -7.821753458e-16) OK. Max cell openness = 3.744188186e-16 OK. Max aspect ratio = 5.877757993 OK. Minimum face area = 5.278152888e-08. Maximum face area = 0.0101113708. Face area magnitudes OK. Min volume = 5.7498987e-10. Max volume = 0.001010488176. Total volume = 124.2733063. Cell volumes OK. Mesh non-orthogonality Max: 61.89625939 average: 4.76190501 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.872508738 OK. Coupled point location match (average 0) OK. Mesh OK. With this mesh when I am running the simulation (dbns-> Roe Flux ->Venkatakrishnan limiter) with blade rpm of 1250, the maximum velocity is becoming too high. Can skewness be the cause of the unphysical simulation? The radius of the blade is 1.48m, NACA 0012 and pitch angle is 8deg. Is it possible to find the most affected cells in paraview? |
dbns, foam extend, openfoam, rotating blade, snappy hex mesh |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
