Pressure fixed value in OpenFoam
Old   June 28, 2021, 06:39
Default Pressure fixed value in OpenFoam
badreddine0 is on a distinguished road
Hello Everyone !!
I am coming to you because I need a little help to run a simulation on Openfoam. I am still new, so the question may seem silly.
I want to run a simulation of a laminar flow in a circular pipe. But, I have an error message for the pressure boundary condition. I can not impose a fixed value for the pressure for any boundary.
Here is the error message:
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type fixedvalue) on patch walls of field p in file "/root/localfolder/pipe/0/p" You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 811.
I obtain exactly the same error for any boundary.
Here is my 0/p file:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedvalue;
        value           uniform 15;
    outlet
        type            fixedvalue;
        value           uniform 0;
    walls
        type            zeroGradient;
    side1
        type            wedge;
    side2
        type            wedge;
Can you help to understand the problem ?
Thank you for helps,
Best regards,
badreddine0 is offline   Reply With Quote
Old   June 28, 2021, 13:27
Default Check boundary condition for velocity
Rahul Vadrabade
Rvadrabade is on a distinguished road
Probably, the velocity boundary condition may not be correctly set with respect to pressure one. If possible can you share the U file boundary conditions.
Rvadrabade is offline   Reply With Quote
Old   June 29, 2021, 11:11
You are right, there was a mistake in 0/U. Thanks you
boundaries condition, openfoam
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 12:23
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
