#calc error: Cant find 'features.h'
Old   October 16, 2018, 16:16
Default #calc error: Cant find 'features.h'
Ballistics_Sim is on a distinguished road
Hello Foamers,
I was hoping to use the #calc directive to help generate the vertices for blockMesh.
I tried to do this and got the following error:
In file included from /home/zwz/OpenFOAM/ThirdParty-v1712/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/c++config.h:507:0,
from /home/zwz/OpenFOAM/ThirdParty-v1712/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/cstddef:49,
from /home/zwz/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/Hasher.H:47,
from /home/zwz/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/string.H:49,
from /home/zwz/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/word.H:43,
from /home/zwz/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/keyType.H:43,
from /home/zwz/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/entry.H:44,
from /home/zwz/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/dictionary.H:88,
from codeStreamTemplate.C:29:
/home/zwz/OpenFOAM/ThirdParty-v1712/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/os_defines.h:39:22: fatal error: features.h: No such file or directory
#include <features.h>
compilation terminated.
/home/zwz/OpenFOAM/OpenFOAM-v1712/wmake/rules/General/transform:28: recipe for target 'Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o' failed
make: *** [Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_2c1a7ee7b5369acae9da148f9823fdd8cde6256a/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_2c1a7ee7b5369acae9da148f9823fdd8cde6 256a.so"
file: /mnt/c/OpenFOAM/Tutorial/pipeCyclic/system/blockMeshDict
From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 219.
FOAM exiting
this is from the simpleFoam/pipeCyclic tutorial, but I was getting the same error in my actual CFD case.
I tried going 'find -name features.h' , found it in another directory then 'cp -r <somePath/features.h> <thePathItWasLookingFor/features.h>'
I tried 'sudo apt-get make' and what was suggested here: https://bugs.openfoam.org/view.php?id=3034.
Still doesnt work. OpenFOAM v1712
What should I do?
Ballistics_Sim is offline   Reply With Quote
Old   February 21, 2020, 13:17
Ravi Teja Paineni
rigid42 is on a distinguished road
hey! did you find any solution for it. I was facing the same problem too. My version is 1912
rigid42 is offline   Reply With Quote
Old   February 21, 2020, 14:16
Ravi Teja Paineni
Never mind found it....
Old   April 24, 2020, 03:05
Franco
otaolafr is on a distinguished road
Originally Posted by rigid42 View Post
hello! i am having the same issue and the link is not working, could you please explaine how to solve it? thanks
otaolafr is offline   Reply With Quote
Old   June 23, 2020, 14:58
Default It worked!
Howard
howard181 is on a distinguished road
Enter "sudo apt-get install build-essential" and restart ubantu
The page:
https://openfoam.org/download/windows-10/
included a few commands for installing OpenFOAM and also the line I mentioned under "Compilation Tools", since I ran into this issue on a new laptop, I suspect not all Third-party softwares were installed with the main OpenFOAM package.
p.s. I'm running on 19.12
howard181 is offline   Reply With Quote
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
Rotation flow calc. II. Andy Christian Main CFD Forum 2 April 10, 2003 04:06
