Ablation with moving mesh
Like Tree1Likes
  • 1 Post By goluba
Old   July 4, 2020, 08:16
Default Ablation with moving mesh
Konstantin Golubkin
goluba is on a distinguished road
Hello!
I solve the problem of burning a solid surface. I need to add a moving boundary in order to implement burning (ablation). Namely, I would like the top layer of mesh cells to be compressed to a certain prescribed value, and then this layer will be disconnected from the solution. In addition, the rate of decrease in cell thickness (compression) should depend on the temperature in these cells. All I found on this forum and in general in Internet resources is that there is a Layer Additional Removal function that seems to implement the desired mesh movement mechanism. But I did not find a single example where there would be a description of this solver setting and which I could take as a basis.
Dear colleagues, did anyone encounter a similar problem, or maybe someone can give a hint on similar solver settings for a moving mesh?
Thanks!
Nikhit Bolar likes this.
goluba is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Moving mesh, field recalulation for ablation Nathanael3 OpenFOAM Running, Solving & CFD 0 August 3, 2013 18:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
