Question about Plotting Vapor Penetration Length |
October 30, 2017, 04:31 |
FengHaifeng
Rep Power: 9 |
Hello!
I'm a beginner of OpenFOAM and I'm using sprayFoam(in OF4.1). I need to plot the liquid penetration length and vapor penetration length, comparing to the standard result to check if my model is correct. Liquid penetration length can be calculated by the function penetration.(fraction)(the pretty standard of fraction for liquid penetration is 0.95), as the following code in SprayCloud.C: template<class CloudType> void Foam::SprayCloud<CloudType>::info() { CloudType::info(); scalar d32 = 1.0e+6*this->Dij(3, 2); scalar d10 = 1.0e+6*this->Dij(1, 0); scalar dMax = 1.0e+6*this->Dmax(); scalar pen = this->penetration(0.95); Info << " D10, D32, Dmax (mu) = " << d10 << ", " << d32 << ", " << dMax << nl << " Liquid penetration 95% mass (m) = " << pen << endl; } But how can I calculate the vapor penetration of every time step? Should I still use this function? Thank you in advance. |
sprayfoam, vapor penetration |
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) | Scabbard | OpenFOAM Running, Solving & CFD | 1 | July 22, 2014 04:50 |
Quick Reference Value Question (Length) | kyles.sverige | FLUENT | 0 | May 9, 2014 15:54 |
Integral Length Scale vs Turbulent Length Scale | Scott Nordsen | FLUENT | 2 | January 20, 2014 01:17 |
Cases with small length scale work fine on a single processor but fail in parallel | adona058 | OpenFOAM Bugs | 5 | April 17, 2009 04:41 |
Characteristic Length Scale | Thomas P. Abraham | Main CFD Forum | 2 | April 20, 1999 17:16 |
