mapped boundary condition
Like Tree16Likes
  • 9 Post By latvietis
  • 6 Post By Linse
  • 1 Post By randolph
Old   May 10, 2012, 07:03
Default mapped boundary condition
Samuele Z
samiam1000 is on a distinguished road
Dear Foamers,
what about the mapped BC? How can I set them? Where can I find an example? Do you think they are good for fixing the patch where I do have 2 different fluid regions?
Thanks a lot,
Samuele.
samiam1000 is offline   Reply With Quote
Old   May 14, 2012, 22:19
Martin
latvietis is on a distinguished road
I'm actually also looking for some kind of tutorial/example. Any luck finding one?
Martin
latvietis is offline   Reply With Quote
Old   May 15, 2012, 02:45
Samuele Z
Hi Martin,
if you agree we can collaborate in order to get something useful.
Please, write me an email and we'll discuss the problem (if you want, of course): samuele.zampini@gmail.com
Have a good day,
Samuele
Old   May 21, 2012, 06:39
Martin
Greetings!
I actually found solution to my problem. Maybe this will give some hint where to start looking.
Firstly, I did search in OpenFOAM tutorials and
openfoam210/tutorials/incompressible/pisoFoam/les/pitzDailyMapped
was my starting point.
Then read .H file, that gives some basic knowladge http://foam.sourceforge.net/docs/cpp/a05692_source.htmlAlso, did a little search in forums and in the end I came up with revelation that it isn't that difficult. So, what worked for me was that I had to edit only 2 files - boundary and field file.
I opened "constant/polyMesh/bounadry"
patch1
        type            patch;
        nFaces          3044;
        startFace       2260730;
and edited it to
    patch1
        type            mappedPatch;
        nFaces          3044;
        startFace       2260730;
        sampleMode      nearestPatchFace;
        samplePatch     patch1a;
        offsetMode      uniform;
        offset          (0 0 0);
then went to "0/field_I_want_to_map"
    patch1
        type                fixedValue;
        value               uniform (0 0 0);
and edited to
    patch1
        type                mapped;
        interpolationScheme cell;
        setAverage          false;
        average             (0 0 0);
and it worked. At least I believe it did. I still have questions to all Foamers out there since there are things I want to understand to be sure about the result I achieved.
1) What is the meaning of 'offset'?
        offsetMode      uniform;
        offset          (0 0 0);
2) What is the meaning of 'averaging' something?
        setAverage          false;
        average             (0 0 0);
Yours,
Martin
Old   May 30, 2012, 06:36
Bernhard Linseisen
Linse is on a distinguished road
Concerning the "offset":
If I am not totally mistaken on this, "offset" gives the distance from the actual boundary where the mapping get's its data.
So if there is boundary A set with an offset of 0.001 it will get the value to map from B in a distance of 0.001 from A. If you set offset to -0.5, A will get the value from C 0.5 upstream of A.
C----(0.5)-------A-(0.001)-B
In case I am wrong on that, please anybody correct me!
For the average thing I do have many speculations, but nothing I would write in here....
Linse is offline   Reply With Quote
Old   July 14, 2016, 07:57
CellZone is on a distinguished road
nFaces          3044; startFace       2260730;
Do I always have to lookup after doing snappyHexMesh under "polymesh/boundary" what mit startFace is and the number of nFaces? Isn't there a way to insert it automatically?
Thank you guys!
CellZone is offline   Reply With Quote
Old   February 10, 2019, 14:54
Reviewer #2
randolph is on a distinguished road
Here is the code that associated with the setAverage
   if (setAverage_)
        Type averagePsi =
            gSum(this->patch().magSf()*newValues)
           /gSum(this->patch().magSf());
        if (mag(averagePsi)/mag(average_) > 0.5)
            newValues *= mag(average_)/mag(averagePsi);
        else
            newValues += (average_ - averagePsi);
    this->operator==(newValues);
So the setAverage is providing the constraints/BC on the mapped value by scaling. If your flow periodicity is well established, then turning off the setAverage should make no difference.
beatlejuice likes this.
randolph is offline   Reply With Quote
Old   July 6, 2020, 18:57
Reviewer #2
   if (setAverage_)
        Type averagePsi =
        else
"If your flow periodicity is well established, then turning off the setAverage should make no difference."
This statement is erroneous, my apology. If you are using the mapped BC as recycling BC for generating turbulence flow in LES, you need to rescale your velocity to keep the same mean bulk velocity.
Old   September 17, 2020, 09:47
Ran Yi
lizzy is on a distinguished road
By this clarification, do you mean that if I run an LES case to generate a fully developed turbulence flow by mapped BC at the inlet, it is necessary to turn on the setAverage switch? That is to say, if the setAverage value is false, the velocity will decrease to zero with time marching because of the friction force?
Many thanks for your kind interpolation!
Regards,
Ran
lizzy is offline   Reply With Quote
Old   September 17, 2020, 09:51
Reviewer #2
Regards,
Ran
Rand
Correct. Also, make sure your recycling length is long enough to allow the turbulence statistics decorrelated.
Thanks,
Rdf
Old   September 17, 2020, 10:14
Ran Yi
Hi Rdf,
I just ran a ring pipe with LES (smagorinsky model) with the recycling mapped method to generate a fully developed turbulence flow as the beginning at a chamber. The recycling length is set as 3*D_out, and the setAverage has been set as true.
However, after about 10 flow through times, I found it is strange that the mean velocity profile near the chamber inlet plane (the offset position of the mapped flow inlet) is something like "laminar" profile rather than a more "flatter" one. If you have some experience with this, can you give me some hints?
Old   September 18, 2020, 09:39
Reviewer #2
Ran,
What is your bulk inlet Reynolds number?
Also, make sure your model has initialized with enough disturbance that can trigger the turbulence.
If your inlet chamber is open channel, I will put the inlet recycling length at least 2pi*D.
If you have everything above correct, then I believe is somewhere in your inlet boundary has problem. You may want to monitor the rescaling and mapped velocity to debug your model.
As a side note, depends on your geometry, OpenFOAM may not be the best choice for LES if your model geometry is relatively simple.
Thanks,
Rdf
Old   November 10, 2021, 06:20
Lorenzo
JesusJoker is on a distinguished road
I am sorry, I am afraid I do not understand what is the value I had to specify if I am just mapping points from a place to another one? (it also seems to be mandatory otherwise it won't run)
JesusJoker is offline   Reply With Quote
Old   November 10, 2021, 06:47
Default i have few doubts regrading the Two Phase Separator
  #14
Akshay
enthusiast is on a distinguished road
Hello Everyone,
I am trying to simulate a two phase separator for water and oxygen, presently I have considered interfoam for this simulation.
I am using OpenFOAM 8, the separator mesh which I am using is attached below. It has 6552 elements.
I am a bit confused regarding whether the solver which I have considered serves the purpose or should I consider MultiphaseEulerFoam where I need to consider another set of equation for oxygen as well?
There is one inlet and two outlets.
Inlet: 2/3rd mass fraction of water and 1/3rd mass fraction of oxygen
Outlet1 is for oxygen and outlet2 is for water.
Other sides are considred as walls and the front and back in Z axis is considered empty.
These are the boundary condition which I have considered
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
walls
type noSlip;
inlet
type flowRateInletVelocity;
massFlowRate constant 0.6667;
outlet1
type pressureInletOutletVelocity;
inletValue uniform (0 0 0);
outlet2
frontandback
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object U;
boundaryField
walls
type noSlip;
inlet
outlet1
outlet2
frontandback
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
walls
type fixedFluxPressure;
value $internalField;
inlet
outlet1
type fixedValue;
outlet2
type fixedValue;
frontandback
type empty;
Please let me know if my boundary conditions are correct?
enthusiast is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
