July 31, 2016, 09:09 |
Random number generation
fluidflowsteel
Rep Power: 9 |
Hi all,
I want to generate random numbers in OF 2.2.0 between -1 and +1 for the whole mesh initially which will remain same for all time steps. Can you advice how to do this ? with regards, |
August 12, 2016, 10:29 |
Tobias Holzmann
Rep Power: 51 |
Simple task,
there is a class called Random. An example is in my Gray-Scott-Solver ... https://bitbucket.org/shor-ty/graysc...e-view-default
Keep foaming, Tobias Holzmann |
December 4, 2019, 05:43 |
#3 | |
George Pichurov
Rep Power: 15 |
December 10, 2019, 23:31 |
#5 | |
Ramkumar
Rep Power: 11 |
Hi, is it possible to generate random list of "N" numbers between given range (a,b)? using that class? Like i need some 10 numbers between say 0 to 100.
And it gives following error when i run that script. Quote:
April 14, 2020, 21:17 |
Example to generate a random number between 0 and 1
Vitor Geraldes
Rep Power: 16 |
#include <iostream>
#include "fvCFD.H" #include "Random.H" #include "Time.H" int main () { Random randObj(clock::getTime()); Info << randObj.scalar01()<< endl; } |
December 1, 2020, 10:19 |
#7 | |
Ramkumar
Rep Power: 11 |
i am getting following error when i use your code. Code:
testCode.C: In function ‘int main(int, char**)’: testCode.C:50:29: error: ‘Foam::scalar Foam::Random::scalar01()’ is private within this context Info << ranObj.scalar01(); |
December 5, 2020, 03:54 |
#8 | |
Mark Olesen
Rep Power: 40 |
Random rng; rng.sample01<scalar>(); Code:
Random::uniformGeneratorOp<scalar> randVal(0,10); scalarField fld(1000); std::generate (fld.begin(), fld.end(), randVal); // the same, as a loop for (scalar& val : fld) { val = randVal(); } |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
random number generation | hwet | Fluent UDF and Scheme Programming | 9 | February 29, 2016 19:35 |
MPI run run fails of quadcore openfoam2.4 | Priya Somasundaran | OpenFOAM Running, Solving & CFD | 3 | January 25, 2016 08:50 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
