Exporting mesh connectivity data to file
Old   November 23, 2020, 21:13
Default Exporting mesh connectivity data to file
alessandro_92 is on a distinguished road
Hello everyone,
This is my first post here. I am a complete beginner in OpenFOAM. I need such software to extract several mesh related data (e.g. face connectivity etc...).
Basically I do my mesh in Salome and then convert it into OpenFOAM. I am able to successfully extract the txt files: points.txt, boundary.txt, neighbour.txt and owner.txt.
However, I would also need other connectivity information such as cell to node connectivity.
I found this website which clarifies exactly what I need: https://jibranhaider.com/blog/mesh-i...sh-coordinates
Being a complete beginner in OpenFOAM, is anybody here willing to give me some advice on where and how exactly I need to implement those commands? Do I need to modify the controlDict file o I need to write a separate C code?
Any help would be greatly appreciated,
Alessandro
alessandro_92 is offline   Reply With Quote
Old   November 25, 2020, 11:17
This is the piece of code that I've written so far.
#include "fvCFD.H"
int main(int argc, char *argv[])
#include "setRootCase.H" // Checks if there is an appropriate system/controlDict
#include "createTime.H" // Constructs the class runTime object of the class time
Foam::Info
<< "Create mesh for time = "
<< runTime.timeName() << Foam::nl << Foam::endl;
Foam::fvMesh mesh
Foam::IOobject
Foam::fvMesh::defaultRegion,
runTime.timeName(),
runTime,
Foam::IOobject::MUST_READ
// Mesh connectivities
// Cells
const labelListList& cellPoints = mesh.cellPoints(); // Cell to node
const labelListList& cellEdges = mesh.cellEdges(); // Cell to edge
const cellList& cells = mesh.cells(); // Cell to face
const labelListList& cellCells = mesh.cellCells(); // Cell to cell
return 0;
And these are the errors that I get:
ExportMesh.C: In function ‘int main(int, char**)’:
ExportMesh.C:90:23: warning: unused variable ‘cellPoints’ [-Wunused-variable]
ExportMesh.C:91:26: warning: unused variable ‘cellEdges’ [-Wunused-variable]
ExportMesh.C:92:21: warning: unused variable ‘cells’ [-Wunused-variable]
ExportMesh.C:93:26: warning: unused variable ‘cellCells’ [-Wunused-variable]
How do I write these variables to .txt files in the "constant" folder?
I do not need to run any "case", I just want to use OpenFOAM as a preprocessor.
Alessandro
Old   November 27, 2020, 21:20
UP.
Any suggestions?
Old   November 28, 2020, 07:03
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by alessandro_92 View Post
UP.
Any suggestions?
If you want to load an OpenFOAM mesh, you do need at least a system/controlDict, it can reasonably small since many of the entries can use their default values. Be certain, however, to create a polyMesh, not an fvMesh or you will need some dummy fvSchemes and fvSolution too.
You are completely free how you write to txt files and where. Use std:: ofstream, OFstream, whatever you like. Just remember to create the output directory if it does not already exist.
Last edited by olesen; November 28, 2020 at 07:04. Reason: Space to avoid automatic emoji
olesen is offline   Reply With Quote
Old   November 28, 2020, 18:23
Thanks for the reply.
Here is the structure of my folders:
- constant
- --> polyMesh (created once I convert my mesh from Salome to Foam)
- system
- --> controlDict (obtained from existing examples)
- --> fvSchemes (obtained from existing examples)
- --> fvSolution (obtained from existing examples)
- ExportMesh (name of my custom .C program)
- --> make
----- --> files
----- --> options
- --> ExportMesh.C
The file "files" contains the following:
ExportMesh.C
EXE = $(FOAM_USER_APPBIN)/ExportMesh
The file "options" contains:
EXE_INC = \
-I../VoF \
-I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
-I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
-I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
-I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
-I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/dynamicFvMesh/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude \
-I$(LIB_SRC)/ExportMesh/lnInclude
EXE_LIBS = \
-limmiscibleIncompressibleTwoPhaseMixture \
-lturbulenceModels \
-lincompressibleTurbulenceModels \
-lfiniteVolume \
-ldynamicFvMesh \
-lfvOptions \
-lmeshTools \
-lsampling \
-lwaveModels
The ExportMesh.C file I wrote is the following (here I just extract
cellPoints):
#include "fvCFD.H"
#include "OFstream.H" // To write data to file
Foam::Info
Foam::fvMesh mesh
Foam::IOobject
runTime.timeName(),
runTime,
// Cells
//const labelListList& cellEdges = mesh.cellEdges(); // Cell to edge
//const cellList& cells = mesh.cells(); // Cell to face
//const labelListList& cellCells = mesh.cellCells(); // Cell to cell
std::fstream file;
file.open ("celltonode.txt", std::fstream::ut | std::fstream::app);
file << runTime.timeName() << " " << cellPoints << std::endl << "\n";
file << nl << endl; // Add new line
file.close();
return 0;
The above code, however, does not return anything except errors.
I need to somehow write to file without making reference to any timestep?
The first part of the long error list is:
ExportMesh.C:100:12: error: no match for ‘operator<<’ (operand types are ‘std::basic_ostream<char>’ and ‘const labelListList {aka const Foam::List<Foam::List<int> >}’)
I need to evaluate cellPoints as a pre-processing step i.e. without running any case.
What am I missing?
Best,
Alessandro
Last edited by alessandro_92; November 28, 2020 at 18:26. Reason: Removed emoticons
Old   December 1, 2020, 12:07
UP. Any other suggestion?
Thanks
Alessandro
Old   December 2, 2020, 03:54
Michael Alletto
mAlletto will become famous soon enough
It seems there is no overloaded operator << in fstream which takes cellPoints (which is a labelList) as imput
See http://www.cplusplus.com/reference/fstream/fstream/
This thread may be useful: Writing/output of simple data into an ASCII-File
mAlletto is offline   Reply With Quote
Old   December 14, 2020, 06:56
Mark Olesen
There are numerous examples of mesh conversion within OpenFOAM, they are always a good place to start. If you are fortunate, perhaps there is something close enough to your requirements that you can hijack it and use a script to reformat the output for your purposes.
In the code snippet, you have gone off and used an std:: ifstream for whatever reason, and then been surprised that it doesn't work. If you stick to using the OpenFOAM variants for IO (eg, a OFstream) you should not experience any issues with the shift operator overloads.
Finally, note that the cellPoints() method is a relatively expensive operation.
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 35 April 29, 2022 15:35
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
