OpenFoam + Docker. Same case different results. |
December 24, 2020, 14:41 |
Ivan
Rep Power: 5 |
Hello everyone,
This is my first post so, sorry if I don't explain my problem properly. I'm trying to validate a well-known case, turbulent flow over NACA0012. Information of the validation ca be found here: https://turbmodels.larc.nasa.gov/naca0012_val.html I simulated properly the case with the version of OpenFoam v2006, obtaining succefull results. I can say that I validated the case because I got accuracy values for Cl and Cd for differents angles of attacks (0º, 3º, 6º, 9º, 12º and 15º). I did that with two different turbulence models (RAS-Spalart Allmaras and RAS-KwSST) using the solver simpleFoam. The problem is the following one. I tried to run the SAME case with a version of OpenFoam installed by means of Docker. (IN THE SAME LAPTOP). Both are supposed to be the same version but the results are differents (Relative error 30 %) and it isn't related with the time of convergence. Has anyone suspect where can be the problem? If someone is interested in look over the code, the case for AoA 3 degrees is here: https://drive.google.com/file/d/1p2P...ew?usp=sharing The case is ready to run with simpleFoam. Thank for your time. Last edited by Ivangzp; December 26, 2020 at 15:08. |
December 28, 2020, 18:51 |
Ivan
Rep Power: 5 |
Anyone can help me or give any recommendation?
December 30, 2020, 12:39 |
Ivan
Rep Power: 5 |
Anyone ? ?
January 1, 2021, 19:51 |
Ivan
Rep Power: 5 |
Help Please!
docker, docker ubuntu centos, openfoam |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
[Other] Installation of OpenFOAM: Docker or not Docker? | zt49 | OpenFOAM Installation | 2 | December 22, 2016 10:38 |
Exporting mesh for an OpenFOAM chtMultiRegion case | akrasemann | enGrid | 14 | October 4, 2015 16:26 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
