Creating a rotating plane for a fan without modelling the blades
Like Tree1Likes
  • 1 Post By linnemann
Old   October 22, 2018, 23:17
Default Creating a rotating plane for a fan without modelling the blades
Kevin Williams
firestone9x is on a distinguished road
Hi all,
I am trying to run a flow simulation in a duct with a fan placed in the middle without modelling the fan blades.
I have the rotational speed of the fan and the inlet velocity and was thinking if its possible to create some sort of rotating plane where the fan is positioned to simulate swirl from that region.
Can someone guide me on how I should proceed?
Thanks.
firestone9x is offline   Reply With Quote
Old   November 6, 2018, 05:33
Kevin Williams
Hi all,
Any responses would be appreciated?
Thanks
Old   November 7, 2018, 11:40
Geir Karlsen
gkarlsen is on a distinguished road
Originally Posted by firestone9x View Post
Hi all,
Thanks.
You could create a baffle in your geometry, and use a cyclic pressure jump condition (see tjunctionfan tutorial if you are not familiar with baffles and cyclic boundary conditions). If you need the swirl you could look into something like the "swirlfanvelocity" as included in v1806:
https://www.openfoam.com/releases/op...conditions.php
gkarlsen is offline   Reply With Quote
Old   November 7, 2018, 14:43
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Could also look at this tutorial.
I made the initial case to test the workings of the rotorDisk.
https://github.com/OpenFOAM/OpenFOAM...Foam/rotorDisk
https://www.openfoam.com/documentati...otor-disk.html
Another way to add swirl is to use porous media. So combine the fan bc with porous media.
http://www.tfd.chalmers.se/~hani/kur...ukurReport.pdf page 10
https://www.openfoam.com/documentati...-jump-fan.html
fumiya likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   November 8, 2018, 03:27
Zander Meiring
yambanshee is on a distinguished road
Try reading up on the actuator disk model if you want realistic simulation of the fan. It makes use of lift and drag data for the fan profile to determine the flow field that would result of the fan. It has been successfully used in applications such as modeling entire air cooled condenser systems for power plants
yambanshee is offline   Reply With Quote
Old   November 12, 2018, 00:02
Kevin Williams
Thanks for all your responses.
I am going to try out your suggestions and keep you'll posted.
Old   January 16, 2019, 12:06
Kevin Williams
Hey all so I was trying to go with the porous media modelling for the fan blades but I cannot find much documentation on the powerLaw and porosity coefficients. Let's say I know the power loss in watts across the fan (assuming I'm modelling a wind turbine) how can I define those values in 'porosity'?
Old   January 23, 2019, 16:22
Kevin Williams
Hello all,
Any responses? Can someone point me to some tutorial or reference material on how to setup and run the cases?
Thanks
Old   February 14, 2019, 11:19
Kevin Williams
Hey all,
I managed to get the actuator disk to work. But I have a doubt regarding the upstream point in FVOptions.
Can someone please explain what exactly it is since I varied the upstream point of the disk but did not notice any change in results.
Thanks,
Kevin
Old   January 18, 2021, 16:05
Default ActuationDisk
Farzad Faraji
farzadmech is on a distinguished road
Dear Kevin Williams
Could you please explain me briefly how did you get ActuationDisk worked?
Farzad
farzadmech is offline   Reply With Quote
Rotating blades of a fan by Fluent? guillaume1990 FLUENT 17 June 22, 2016 03:01
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Rotating blades of a fan Fluent? guillaume1990 ANSYS 1 March 21, 2014 03:15
fan rotating tongnan FLUENT 1 February 7, 2013 16:50
Help need to simulate flow around Contra rotating Fan venkat_aero2007 Fidelity CFD 0 July 31, 2012 14:01
