Second Derivative Zero - Boundary Condition
Like Tree10Likes
  • 2 Post By eugene
  • 7 Post By eugene
  • 1 Post By waelitani
Old   June 21, 2011, 04:52
Default Second Derivative Zero - Boundary Condition
Fu
fu-ki-pa is on a distinguished road
Hi Everybody !
Greetings
I am doing a natural convection problem in which i want to put second derivative of a scalar =0. How can i implement it in openFoam?
Mathematically
\frac{d^2 T}{dx^2} = 0 or \frac{d^2 T}{dy^2} = 0
Thanks and Regards
Fuki
fu-ki-pa is offline   Reply With Quote
Old   June 22, 2011, 17:28
Eugene de Villiers
eugene is on a distinguished road
There might be other ways, but I use a fixed gradient boundary and then set the gradient on the boundary equal to n.grad(f) in the near wall cell. So if the gradient normal to the wall is equal to that in the adjacent cell then the "gradient of the gradient" is zero. Of course this is explicit and therefore lags the solution by an iteration.
Eugene
verby and fu-ki-pa like this.
eugene is offline   Reply With Quote
Old   June 23, 2011, 03:56
Fu
Thank a lot Eugene !
Old   June 25, 2011, 13:51
Mohammad.R.Shetab
mrshb4 is on a distinguished road
Dear Eugene
You're right, and that's smart!!
But would you tell me please how would you implement that fixedGradient boundary condition?! I think you would write a new boundary condition and edit the codes in fxedGradient, or do you have any other way?
Thank you
Mohammadreza
mrshb4 is offline   Reply With Quote
Old   June 27, 2011, 17:06
Eugene de Villiers
No you don't edit fixedGradient. You find another boundary that is derived from fixedGradient, copy it to another name and then edit it.
Old   June 28, 2011, 07:28
jawed mustafa
jawed is on a distinguished road
Dear Eugene,
can you shed more light on its implementation
jawed
jawed is offline   Reply With Quote
Old   June 29, 2011, 04:05
Eugene de Villiers
Well, you calculate the gradient of the field in question and then for each face in your boundary find the the cell adjacent to it. You then set the gradient on the boundary equal to the surface normal component of the gradient in the near-wall cell. To make things more cost-effective, you probably want to calculate the gradient once per iteration and then store it in the database.
Attached should be an old version of such a boundary I made for use with boundaryFoam. Note it does not have any cost-reduction measures in place - you will have to figure these out yourself.
chegdan, fu-ki-pa, jawed and 4 others like this.
Old   June 29, 2011, 04:57
jawed mustafa
Dear Eugene,
it seems to work thanks for the patch
jawed
Old   July 3, 2011, 20:58
Mohammad.R.Shetab
Dear Eugene,
Would you please tell me how to compile your bc. I have both openFOAMs 1.5-dev & 1.7.1. In 1.5-dev it has an error finding "uniformDimensionedFields.H". It seems that there is no such file in OF-1.5-dev. But in 1.7.1 it would give another error that is:
/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crt1.o: In function `_start':
(.text+0x18): undefined reference to `main'
Make/linuxGccSPOpt/nearWallDist.o: In function `Foam::nearWallDist::doAll()':
nearWallDist.C.text+0x19b): undefined reference to `Foam::cellDistFuncs::cellDistFuncs(FoamlyMesh const&)'
nearWallDist.C.text+0x1c9): undefined reference to `Foam::cellDistFuncs::maxPatchSize(Foam::HashSet<i nt, Foam::Hash<int> > const&) const'
nearWallDist.C.text+0x2f9): undefined reference to `Foam::cellDistFuncs::getPointNeighbours(Foam::Pri mitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<float> > const&, Foam::Vector<float> > const&, int, Foam::List<int>&) const'
nearWallDist.C.text+0x34a): undefined reference to `Foam::cellDistFuncs::smallestDist(Foam::Vector<fl oat> const&, FoamlyPatch const&, int, Foam::List<int> const&, int&) const'
Make/linuxGccSPOpt/wallDist.o: In function `Foam::wallDist::correct()':
wallDist..text+0x2ad): undefined reference to `Foam:atchWave:atchWave(FoamlyMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, bool)'
wallDist.C.text+0x58b): undefined reference to `Foam:atchWave::~patchWave()'
wallDist.C.text+0x640): undefined reference to `Foam:atchWave::~patchWave()'
Make/linuxGccSPOpt/wallDist.o: In function `Foam::wallDist::wallDist(Foam::fvMesh const&, bool)':
wallDist.C.text+0xeba): undefined reference to `Foam::cellDistFuncs::cellDistFuncs(FoamlyMesh const&)'
wallDist.C.text+0x124a): undefined reference to `Foam::cellDistFuncs::cellDistFuncs(FoamlyMesh const&)'
Make/linuxGccSPOpt/wallDistReflection.o: In function `Foam::FaceCellWave<Foam::wallPointData<Foam::Vect or<float> > >::readFaces(int&, Foam::List<int>&, Foam::List<Foam::wallPointData<Foam::Vector<float> > >&, Foam::Istream&)':
wallDistReflection.C.text._ZN4Foam12FaceCellWaveIN S_13wallPointDataINS_6VectorIfEEEEE9readFacesERiRN S_4ListIiEERNS7_IS4_EERNS_7IstreamE[Foam::FaceCellWave<Foam::wallPointData<Foam::Vecto r<float> > >::readFaces(int&, Foam::List<int>&, Foam::List<Foam::wallPointData<Foam::Vector<float> > >&, Foam::Istream&)]+0x9e): undefined reference to `Foamerator>>(Foam::Istream&, Foam::wallPoint&)'
Make/linuxGccSPOpt/wallDistReflection.o: In function `Foam::FaceCellWave<Foam::wallPointData<Foam::Vect or<float> > >::writeFaces(int, Foam::List<int> const&,
`Foam::directMappedVelocityFluxFixedValueFvPatchFi eld::directMappedVelocityFluxFixedValueFvPatchFiel d(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<float>, Foam::volMesh> const&, Foam::dictionary const&)':
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x2bea): undefined reference to `typeinfo for Foam::directMappedPatchBase'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x2c15): undefined reference to `typeinfo for Foam::directMappedPolyPatch'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x2d40): undefined reference to `Foam::directMappedPatchBase::typeName'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x2e27): undefined reference to `Foam::directMappedPatchBase::calcMapping() const'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x3043): undefined reference to `Foam::directMappedPolyPatch::typeName'
directMappedVelocityFluxFixedValueFvPatchField.Cte xt+0x306b): undefined reference to `typeinfo for Foam::directMappedPolyPatch'
Make/linuxGccSPOpt/directMappedVelocityFluxFixedValueFvPatchField.o: In function `Foam::directMappedVelocityFluxFixedValueFvPatchFi eld::directMappedVelocityFluxFixedValueFvPatchFiel d(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<float>, Foam::volMesh> const&, Foam::dictionary const&)':
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x319a): undefined reference to `typeinfo for Foam::directMappedPatchBase'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x31c5): undefined reference to `typeinfo for Foam::directMappedPolyPatch'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x32f0): undefined reference to `Foam::directMappedPatchBase::typeName'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x33d7): undefined reference to `Foam::directMappedPatchBase::calcMapping() const'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x35f3): undefined reference to `Foam::directMappedPolyPatch::typeName'
directMappedVelocityFluxFixedValueFvPatchField.C.t ext+0x361b): undefined
timeVaryingMappedPressureDirectedInletVelocityFvPa tchVectorField.C.text._ZN4Foam39timeVaryingMappedF ixedValueFvPatchFieldINS_6VectorIfEEE16readSampleP ointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<float> >::readSamplePoints()]+0x75d): undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const'
timeVaryingMappedPressureDirectedInletVelocityFvPa tchVectorField.C.text._ZN4Foam39timeVaryingMappedF ixedValueFvPatchFieldINS_6VectorIfEEE16readSampleP ointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<float> >::readSamplePoints()]+0xa1d): undefined reference to `Foam::triSurfaceTools::calcInterpolationWeights(F oam::triSurface const&, Foam::Field<Foam::Vector<float> > const&, Foam::List<Foam::FixedList<int, 3u> >&, Foam::List<Foam::FixedList<float, 3u> >&)'
timeVaryingMappedPressureDirectedInletVelocityFvPa tchVectorField.C.text._ZN4Foam39timeVaryingMappedF ixedValueFvPatchFieldINS_6VectorIfEEE16readSampleP ointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<float> >::readSamplePoints()]+0xc12): undefined reference to `Foam::triSurface::~triSurface()'
timeVaryingMappedPressureDirectedInletVelocityFvPa tchVectorField.C.text._ZN4Foam39timeVaryingMappedF ixedValueFvPatchFieldINS_6VectorIfEEE16readSampleP ointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Vector<float> >::readSamplePoints()]+0x15a9): undefined reference to `Foam::triSurface::~triSurface()'
Make/linuxGccSPOpt/timeVaryingMappedFixedValueFvPatchFields.o: In function `Foam::timeVaryingMappedFixedValueFvPatchField<flo at>::readSamplePoints()':
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldIfE 16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<floa t>::readSamplePoints()]+0x4e9): undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::wo rd const&, Foam::Vector<float> const&, Foam::Vector<float> const&, Foam::Vector<float> const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldIfE 16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<floa t>::readSamplePoints()]+0x5f9): undefined reference to `Foam::triSurfaceTools::delaunay2D(Foam::List<Foam ::Vector2D<float> > const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldIfE 16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<floa t>::readSamplePoints()]+0x725): undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldIfE 16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<floa t>::readSamplePoints()]+0x9e5): undefined reference to `Foam::triSurfaceTools::calcInterpolationWeights(F oam::triSurface const&, Foam::Field<Foam::Vector<float> > const&, Foam::List<Foam::FixedList<int, 3u> >&, Foam::List<Foam::FixedList<float, 3u> >&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldIfE 16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<floa t>::readSamplePoints()]+0xbcb): undefined reference to `Foam::triSurface::~triSurface()'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldIfE 16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<floa t>::readSamplePoints()]+0x156c): undefined reference to `Foam::triSurface::~triSurface()'
Make/linuxGccSPOpt/timeVaryingMappedFixedValueFvPatchFields.o: In function `Foam::timeVaryingMappedFixedValueFvPatchField<Foa m::Tensor<float> >::readSamplePoints()':
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _6TensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Tensor<float> >::readSamplePoints()]+0x4e9): undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::wo rd const&, Foam::Vector<float> const&, Foam::Vector<float> const&, Foam::Vector<float> const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _6TensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Tensor<float> >::readSamplePoints()]+0x5f9): undefined reference to `Foam::triSurfaceTools::delaunay2D(Foam::List<Foam ::Vector2D<float> > const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _6TensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Tensor<float> >::readSamplePoints()]+0x725): undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _6TensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Tensor<float> >::readSamplePoints()]+0x9e5): undefined reference to `Foam::triSurfaceTools::calcInterpolationWeights(F oam::triSurface const&, Foam::Field<Foam::Vector<float> > const&, Foam::List<Foam::FixedList<int, 3u> >&, Foam::List<Foam::FixedList<float, 3u> >&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _6TensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Tensor<float> >::readSamplePoints()]+0xbcb): undefined reference to `Foam::triSurface::~triSurface()'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _6TensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::Tensor<float> >::readSamplePoints()]+0x156c): undefined reference to `Foam::triSurface::~triSurface()'
Make/linuxGccSPOpt/timeVaryingMappedFixedValueFvPatchFields.o: In function `Foam::timeVaryingMappedFixedValueFvPatchField<Foa m::SphericalTensor<float> >::readSamplePoints()':
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _15SphericalTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SphericalTensor<float> >::readSamplePoints()]+0x4e9): undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::wo rd const&, Foam::Vector<float> const&, Foam::Vector<float> const&, Foam::Vector<float> const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _15SphericalTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SphericalTensor<float> >::readSamplePoints()]+0x5f9): undefined reference to `Foam::triSurfaceTools::delaunay2D(Foam::List<Foam ::Vector2D<float> > const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _15SphericalTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SphericalTensor<float> >::readSamplePoints()]+0x725): undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _15SphericalTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SphericalTensor<float> >::readSamplePoints()]+0x9e5): undefined reference to `Foam::triSurfaceTools::calcInterpolationWeights(F oam::triSurface const&, Foam::Field<Foam::Vector<float> > const&, Foam::List<Foam::FixedList<int, 3u> >&, Foam::List<Foam::FixedList<float, 3u> >&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _15SphericalTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SphericalTensor<float> >::readSamplePoints()]+0xbcb): undefined reference to `Foam::triSurface::~triSurface()'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _15SphericalTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SphericalTensor<float> >::readSamplePoints()]+0x156c): undefined reference to `Foam::triSurface::~triSurface()'
Make/linuxGccSPOpt/timeVaryingMappedFixedValueFvPatchFields.o: In function `Foam::timeVaryingMappedFixedValueFvPatchField<Foa m::SymmTensor<float> >::readSamplePoints()':
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _10SymmTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SymmTensor<float> >::readSamplePoints()]+0x4e9): undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::wo rd const&, Foam::Vector<float> const&, Foam::Vector<float> const&, Foam::Vector<float> const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _10SymmTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SymmTensor<float> >::readSamplePoints()]+0x5f9): undefined reference to `Foam::triSurfaceTools::delaunay2D(Foam::List<Foam ::Vector2D<float> > const&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _10SymmTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SymmTensor<float> >::readSamplePoints()]+0x725): undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _10SymmTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SymmTensor<float> >::readSamplePoints()]+0x9e5): undefined reference to `Foam::triSurfaceTools::calcInterpolationWeights(F oam::triSurface const&, Foam::Field<Foam::Vector<float> > const&, Foam::List<Foam::FixedList<int, 3u> >&, Foam::List<Foam::FixedList<float, 3u> >&)'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _10SymmTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SymmTensor<float> >::readSamplePoints()]+0xbcb): undefined reference to `Foam::triSurface::~triSurface()'
timeVaryingMappedFixedValueFvPatchFields.C.text._Z N4Foam39timeVaryingMappedFixedValueFvPatchFieldINS _10SymmTensorIfEEE16readSamplePointsEv[Foam::timeVaryingMappedFixedValueFvPatchField<Foam ::SymmTensor<float> >::readSamplePoints()]+0x156c): undefined reference to `Foam::triSurface::~triSurface()'
Make/linuxGccSPOpt/porousZone.o: In function `FoamrousZone::writeDict(Foam::Ostream&, bool) const':
porousZone.C.text+0x1224): undefined reference to `Foam::coordinateSystem::writeDict(Foam::Ostream&, bool) const'
Make/linuxGccSPOpt/porousZone.o: In function `FoamrousZonerousZone(Foam::word const&, Foam::fvMesh const&, Foam::dictionary const&)':
porousZone.C.text+0x1813): undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::di ctionary const&, Foam:bjectRegistry const&)'
porousZone.C.text+0x2b84): undefined reference to `Foam::coordinateSystem::~coordinateSystem()'
porousZone.C.text+0x2df3): undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::di ctionary const&, Foam:bjectRegistry const&)'
porousZone.C.text+0x4103): undefined reference to `Foam::coordinateSystem::~coordinateSystem()'
Make/linuxGccSPOpt/porousZone.o: In function `FoamrousZone::~porousZone()':
porousZone.C.text._ZN4Foam10porousZoneD1Ev[FoamousZone::~porousZone()]+0x4f): undefined reference to `Foam::coordinateSystem::~coordinateSystem()'
porousZone.C.text._ZN4Foam10porousZoneD0Ev[FoamrousZone::~porousZone()]+0x53): undefined reference to `Foam::coordinateSystem::~coordinateSystem()'
Make/linuxGccSPOpt/MRFZone.o: In function `Foam::MRFZone::setMRFFaces()':
MRFZone.C.text+0x194a): undefined reference to `Foam::faceSet::faceSet(FoamlyMesh const&, Foam::word const&, Foam::HashSet<int, Foam::Hash<int> > const&, Foam::IOobject::writeOption)'
MRFZone.C.text+0x1a98): undefined reference to `Foam::faceSet::faceSet(FoamlyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)'
MRFZone.C.text+0x1f67): undefined reference to `Foam::faceSet::~faceSet()'
MRFZone.C.text+0x1f75): undefined reference to `Foam::faceSet::~faceSet()'
MRFZone.C.text+0x1f83): undefined reference to `Foam::faceSet::~faceSet()'
MRFZone.C.text+0x21d4): undefined reference to `Foam::faceSet::faceSet(FoamlyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)'
MRFZone.C.text+0x26b9): undefined reference to `Foam::faceSet::~faceSet()'
MRFZone.C.text+0x2720): undefined reference to `Foam::faceSet::~faceSet()'
MRFZone.C.text+0x2766): undefined reference to `Foam::faceSet::~faceSet()'
MRFZone.C.text+0x27aa): undefined reference to `Foam::faceSet::~faceSet()'
Make/linuxGccSPOpt/pressureGradientExplicitSource.o: In function `Foam:ressureGradientExplicitSource:ressureGradien tExplicitSource(Foam::word const&, Foam::GeometricField<Foam::Vector<float>, Foam::fvPatchField, Foam::volMesh>&)':
pressureGradientExplicitSource.C.text+0x559): undefined reference to `Foam::topoSetSource::New(Foam::word const&, Foam:olyMesh const&, Foam::dictionary const&)'
pressureGradientExplicitSource.C.text+0x61c): undefined reference to `Foam::cellSet::cellSet(FoamlyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)'
pressureGradientExplicitSource.C.text+0xe87): undefined reference to `Foam::cellSet::~cellSet()'
pressureGradientExplicitSource.C.text+0x1759): undefined reference to `Foam::topoSetSource::New(Foam::word const&, FoamlyMesh const&, Foam::dictionary const&)'
pressureGradientExplicitSource.C.text+0x181c): undefined reference to `Foam::cellSet::cellSet(FoamlyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)'
pressureGradientExplicitSource.C.text+0x2087): undefined reference to `Foam::cellSet::~cellSet()'
Make/linuxGccSPOpt/basicSource.o: In function `Foam::basicSource::setCellSet()':
basicSource.C.text+0x1430): undefined reference to `Foam::cellSet::cellSet(FoamlyMesh const&, Foam::word const&, Foam::IOobject::readOption, Foam::IOobject::writeOption)'
basicSource.C.text+0x147d): undefined reference to `Foam::cellSet::~cellSet()'
basicSource.C.text+0x164c): undefined reference to `Foam::cellSet::~cellSet()'
collect2: ld returned 1 exit status
make: *** [OpenFOAM.out] Error 1
I just copy the extrapolatedGradient folder in the path :
/home/mrshb4/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/fields/fvPatchFields/basic/extrapolatedGradient
could you please tell me how can I compile that?!!
Thanks
Mohammadreza
Old   December 23, 2013, 07:17
Thamali
Thamali is on a distinguished road
Did you get through these errors,although it is too late to ask this from you.I got similar type of errors.Il put them below.Please see whether you can help me.Im stucked at this point for some days.
thamali@thamali-VirtualBox:~/OpenFOAM/thamali-2.2.2/applications/solvers/my_fireFoam11$ Make/linuxGccDPOpt/my_fireFoam.o: In function `Foam::fv::laplacianScheme<double, Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)':
my_fireFoam.C.text._ZN4Foam2fv15laplacianSchemeI dNS_6VectorIdEEE3NewERKNS_6fvMeshERNS_7IstreamE[Foam::fv::laplacianScheme<double, Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)]+0x53): undefined reference to `Foam::fv::laplacianScheme<double, Foam::Vector<double> >::IstreamConstructorTablePtr_'
my_fireFoam.C.text._ZN4Foam2fv15laplacianSchemeI dNS_6VectorIdEEE3NewERKNS_6fvMeshERNS_7IstreamE[Foam::fv::laplacianScheme<double, Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)]+0x1a5): undefined reference to `Foam::fv::laplacianScheme<double, Foam::Vector<double> >::IstreamConstructorTablePtr_'
my_fireFoam.C.text._ZN4Foam2fv15laplacianSchemeI dNS_6VectorIdEEE3NewERKNS_6fvMeshERNS_7IstreamE[Foam::fv::laplacianScheme<double, Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)]+0x1d5): undefined reference to `Foam::fv::laplacianScheme<double, Foam::Vector<double> >::IstreamConstructorTablePtr_'
make: *** [/home/thamali/OpenFOAM/thamali-2.2.2/platforms/linuxGccDPOpt/bin/my_fireFoam] Error 1
Thamali is offline   Reply With Quote
Old   May 1, 2014, 16:26
Dan_Sobien is on a distinguished road
Would it be possible to edit this patch type to include vectors as well? Thanks for any advice or info.
Dan_Sobien is offline   Reply With Quote
Old   March 27, 2021, 04:28
Default Updated
  #12
Wael Itani
waelitani is on a distinguished road
I have modified the extrapolated Gradient boundary condition above to work with OpenFOAM v8.
Enjoy,
dimasbarile likes this.
waelitani is offline   Reply With Quote
boundary condition, natural convection, openfoam
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
problem with boundary condition??? smn CFX 5 November 24, 2009 06:37
