Problem in using chtMultiRegionFoam for steady-state |
May 3, 2021, 12:09 |
Muhammed Emin POLAT
Rep Power: 5 |
Hello all,
A physical problem occurs when I am configuring chtMultiRegionFoam as steady-state. Previous releases of OpenFOAM had included chtMultiRegionSimpleFoam for steady problems before OpenFOAM foundation merged transient and steady solver. My problem is that even if it is not a transient case, the behaviour of my model is quite similar to transient due to higher diffusion number. I have three bodies where one of them is placed for conduction and other two are for both convection and conduction. Because of the relatively larger volume of region for conduction heat tranfer, convergence delays enormously. The question, therefore, is about whether I can modify this problem so that it satisfies a quick convergence? Else, is it possible to integrate chtMultiRegionSimpleFoam in OF v8? Thanks a lot for your replies. |
May 4, 2021, 05:59 |
Sergei
Rep Power: 21 |
Very slow convergence might be attributed to the fact that cht solver in question can only solve multiregion problems in segregated way, region by region, which makes solving a problem with lots of regions very annoying. Steady version will not resolve your issue.
May 6, 2021, 10:36 |
Muhammed Emin POLAT
Rep Power: 5 |
Thank you for your reply, Zeppo. Then, my question is to be evolved. I would like to set Pseudo transient approach to reach steady-state condition faster. I have attempted many times but have not accomplished yet. Is it not embedded in chtMultiRegionFoam solver in OF?
May 6, 2021, 14:23 |
Mark Olesen
Rep Power: 40 |
Just for this reason there is possibility to add additional cycles for the temperature equation. Can't remember exactly, but I think it went into the 1706 or 1712 release.
May 16, 2021, 10:42 |
Sergei
Rep Power: 21 |
Alternatively, you can go for foam-extend version which offers coupled solver.
OpenFOAM 6, chtMultiRegionFoam residualcontrol for steady state not working | qtruong | OpenFOAM Running, Solving & CFD | 10 | December 18, 2019 02:24 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Problem with pimpleDyMFoam: Initialise steady state solution | Lancester | OpenFOAM Running, Solving & CFD | 2 | September 29, 2015 09:49 |
Problem setting with chtmultiregionFoam | Antonin | OpenFOAM | 10 | April 24, 2012 09:50 |
convergence problem in 3D steady state, laminar flow in a bath | vajiheh | FLUENT | 0 | July 10, 2009 12:18 |
