Error while running a test case in modified interFoam
Like Tree1Likes
  • 1 Post By HPE
Old   June 27, 2021, 11:56
Default Error while running a test case in modified interFoam
Sourav Hossain
sourav8016 is on a distinguished road
Hi Foamers,
I added an extra equation(sediment concentration equation) in interFoam and accordingly I have modified interFoam code. while running a test case the following error comes. Please help me out. Thanks in advance.
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 23 the doubleScalar 1e-06
file: /home/souravhossain/OpenFOAM/souravhossain-8/run/mySuspendedSedFoam/openChannel/constant/transportProperties/water/nu at line 23.
From function Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::word&)
in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
N.B. I'm using openfoam8.
sourav8016 is offline   Reply With Quote
Old   June 27, 2021, 14:43
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
it seems that transportProperties/water/nu file should have some typo or a missing entry component. could you double check the file, and/or share the file?
HPE is offline   Reply With Quote
Old   June 27, 2021, 15:18
Sourav Hossain
Thanks for your kind reply. After modifying the transportProperties file, that error has gone
phases (water air);
water
transportModel Newtonian;
// nu 1e-06;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-06; //previously I was not mentioning dimension.
rho 1000;
air
nu 1.48e-05;
rho 1;
sigma 0.07;
But now I 'm getting another error :
-> FOAM FATAL ERROR:
LHS and RHS of + have different dimensions
dimensions : [0 0 0 0 0 0 0] + [0 2 0 0 0 0 0]
From function Foam::dimensionSet Foam:perator+(const Foam::dimensionSet&, const Foam::dimensionSet&)
in file dimensionSet/dimensionSet.C at line 501.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam:perator+(Foam::dimensionSet const&, Foam::dimensionSet const&) at ??:?
#3 Foam::dimensioned<double> Foam:perator+<double>(Foam::dimensioned<double> const&, Foam::dimensioned<double> const&) at ??:?
#4 Foam:perator+(double, Foam::dimensioned<double> const&) at ??:?
#5 ? in "/home/souravhossain/OpenFOAM/souravhossain-8/platforms/linux64GccDPInt32Opt/bin/mySuspendedSedFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? in "/home/souravhossain/OpenFOAM/souravhossain-8/platforms/linux64GccDPInt32Opt/bin/mySuspendedSedFoam"
Aborted (core dumped)
N.B. for further communication please inbox me at hossainsourav101@gmail.com through mail. I would be very happy to share my files. Thanks for your consideration.
Old   June 27, 2021, 15:34
HPE
HPE's Avatar
- The new error indicates that somewhere in your modification there is an inconsistency in dimensions in one of the operations. Possibly, you need to use a "dimensionedScalar" type instead of a "scalar" type in your new code. (pure speculation without seeing the code).
- I'm afraid, I prefer the public domain for any info exchange, so that other users could benefit from it wherever appropriate - because I do 100% non-paid volunteering here (also learning from others). Thanks for your understanding.
sourav8016 likes this.
Old   June 28, 2021, 03:22
Sourav Hossain
Dear Sir, I was not aware of how to add files here. Now I am done. I have added two files
here. One file (https://www.dropbox.com/s/3dm2pet3ut...Added.pdf?dl=0) consists of my equations to be added in interFoam and other file(attached) consits of OpenFoam code. Please have a look. I am looking forward your valuable suggestion. Thanks in advance.
N.B. that dimensional error has now gone. Now another error came while running testcase:
--> FOAM FATAL ERROR:
Attempted assignment to a const reference to an object of type N4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volM eshEEE
From function void Foam::tmp<T>:perator=(const Foam::tmp<T>&) [with T = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
in file /opt/openfoam8/src/OpenFOAM/lnInclude/tmpI.H at line 379.
FOAM aborting
#2 ? in "/home/souravhossain/OpenFOAM/souravhossain-8/platforms/linux64GccDPInt32Opt/bin/mySuspendedSedFoam"
#3 ? in "/home/souravhossain/OpenFOAM/souravhossain-8/platforms/linux64GccDPInt32Opt/bin/mySuspendedSedFoam"
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Old   July 1, 2021, 16:06
HPE
HPE's Avatar
2D flow around a circular cylinder case with interFoam solver shuoxue OpenFOAM Running, Solving & CFD 2 January 14, 2020 13:23
[Other] Running test case of PATO sonGoku OpenFOAM Community Contributions 0 September 21, 2018 08:38
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Running axis-symmetric case houkensjtu OpenFOAM 3 October 5, 2012 02:32
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 18:46
