August 20, 2021, 08:49 |
Solids4Foam anisotropic solver
Angu Praveen
Rep Power: 7 |
Dear all,
Currently, I am trying to check the solution from the solids4Foam solver with the anisotropicBiotFoam written by another researcher Tian Tang. I would like to know, how I can reproduce these results using solids4Foam? As I am relatively very new to solids4Foam, I would like to know what are the input files that have to be changed in order to replicate a similar result using s4F? 1. In anisotropic, we have different young’s moduli. How to add this in s4F? 2. How to know which solver to use? The link to Tian Tang's Bitbucket is: https://bitbucket.org/tiantang/minig...utorials/soil/ Any information from you would be really helpful Regards Angu |
August 26, 2021, 12:23 |
Philip Cardiff
Rep Power: 34 |
Hi Angu,
solids4foam currently contains some examples of anisotropic mechanical law, e.g. see the following tutorial: Code:
soldis4foam-release/tutorials/solids/linearElasticity/plateHole/plateHoleOrthotropic/constant/mechanicalProperties Code:
mechanical ( carbonFibre { type orthotropicLinearElastic; rho rho [1 -3 0 0 0 0 0] 7854; E1 E1 [1 -1 -2 0 0 0 0] 200e+9; E2 E2 [1 -1 -2 0 0 0 0] 50e+9; E3 E3 [1 -1 -2 0 0 0 0] 50e+9; nu12 nu12 [0 0 0 0 0 0 0] 0.3; nu23 nu23 [0 0 0 0 0 0 0] 0.3; nu31 nu31 [0 0 0 0 0 0 0] 0.075; G12 G12 [1 -1 -2 0 0 0 0] 20e+9; G23 G23 [1 -1 -2 0 0 0 0] 20e+9; G31 G31 [1 -1 -2 0 0 0 0] 20e+9; // Local material directions can be specified here or as fields // If not specified, then the Cartesian unit vectors are assumed //materialDirectionX (1 0 0); //materialDirectionY (0 1 0); //materialDirectionZ (0 0 1); } ); However, in your case, you want to reproduce the results from Tang's minigeotechfoam repo. I had not ported the anisotropicBiotFoam mechanical law (it is embedded in the solver in the calculateSigmaEpsilonOrtho.H header file), but, it is straight-forward to port so I have just pushed it to the development branch (commit e297b1e2). See the new tutorial: Code:
solids4foam-release/tutorials/solids/poroelasticity/rodAndSeabed Have a look at the pushed code and case and let me know if it works for you (git checkout development && git pull && ./Allwmake). If you are happy to, you can modify the pEqn in: Code:
solids4foam/src/solids4FoamModels/solidModels/poroLinGeomSolid/poroLinGeomSolid.C Philip |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
