how to achieve homogeneous vertical profile for turbulence
Like Tree2Likes
  • 1 Post By mAlletto
Old   August 16, 2021, 13:48
Default how to achieve homogeneous vertical profile for turbulence
Saugat Shrestha
saugatshr4 is on a distinguished road
I am working on turbulence modeling of the Atmospheric Boundary Layer. Here I have been able to maintain a homogeneous wind velocity profile. However, I have been unable to maintain a homogeneous profile for tubrulence.
I have given a manual input for the Turbulent Kinetic energy (TKE). It seems that the TKE seems to dissipate very early in the domain and doesn't travel the domain. I have attached a picture of the TKE in the along wind direction of the domain.
FYI, I'm trying to implement a k-epsilon model.
Can anybody please help me. I have been stuck in this problem for a long time.
I will be very grateful for your help.
Thank You.
With best regards,
Saugat
saugatshr4 is offline   Reply With Quote
Old   August 16, 2021, 16:27
Michael Alletto
mAlletto will become famous soon enough
That's probably because the inflow tke is not a solution of the homogeneous equation. If you run a flat plate simulation with periodic boundary conditions in stream wise direction you will get your homogeneous solution.
tariq likes this.
mAlletto is offline   Reply With Quote
Old   August 17, 2021, 09:27
Saugat Shrestha
Thank You mAlletto, for the response.
The advice you gave me did work and now I am able to conserve the turbulence in my model domain.
So, I gave the cyclic boundary layer inputs to the inlet and the outlet. Due to this I had to use fvOptions to give the velocity and turbulence input parameters. For the velocity I used the patchMeanVelocityForce function.
However, here I could only give the a fixed value. I require to give a profile here. I tried using the fixed profile function from a CSV here but could implement it.
Can you please help me give give a profile to those parameters?
Your help will be really valuable in my work.
Thank You.
With best regards,
Saugat
This is for the fixed value of velocity
momentumSource
type patchMeanVelocityForce;
active yes;
patchMeanVelocityForceCoeffs
selectionMode all;
fields (U);
patch inlet;
Ubar (0 8 0);
relaxation 0.2;
I tried this it doesn't work (its more like a wild guess):
momentumSource
active yes;
selectionMode all;
fields (U);
patch inlet;
U
type fixedProfile;
profile csvFile;
profileCoeffs
nHeaderLine 0;
refColumn 0;
componentColumns (1);
separator ",";
mergeSeparators 0;
outOfBounds clamp;
file "C:\Program Files\blueCFD-Core-2017\ofuser-of5\run\manualK_20210812\0\Book2.csv";
direction (0 0 1);
origin 0;
relaxation 0.2;
Old   August 17, 2021, 15:19
Michael Alletto
I didn't understand your question. Can you be more precise
Old   August 18, 2021, 08:36
Saugat Shrestha
Hello mAlletto,
I implemented the periodic boundary condition but I don't get a homogeneous solution.
I have attached the profile of the TKE profile and epsilon profile. The TKE is for some reason getting attached to the top. Even in the epsilon profile, there are higher values at the top. However, for epsilon, the profile at the bottom is something that I want.
FYI, I am getting a homogeneous profile for the wind speed but turbulence is a big problem for me.
I am using a slip condition on the top layer. For the inlet and the outlet, I'm using cyclic boundary conditions. I have given a profile of wind speed, turbulence kinetic energy, and epsilon using the fvoption.
Can you suggest a solution for this?
With best regards,
Saugat
Old   August 18, 2021, 17:00
Michael Alletto
Seems like you have a source term in the middle of the domain. To achieve a homogeneous solution only a few cells in stream wise direction are required. Can you also post the velocity
Old   August 18, 2021, 17:05
Michael Alletto
You find a tutorial how to achieve a homogeneous solution for an atmospheric boundary layer here https://develop.openfoam.com/Develop...atmFlatTerrain
Old   September 17, 2021, 00:11
Saugat Shrestha
Sorry, mAlletto for the late response.
As request by you, I have attached the velocity profile.
Thank You.
Old   January 24, 2022, 04:33
DJF
DJF is on a distinguished road
Very interesting tutorial, mAlletto! I've been struggling with an ABL simulation of a complex terrain using LES and DFSEM. The velocity profile changes rapidly in streamwise direction, especially near the ground surface where I get much larger velocities compared to the reference profile.
I'm currently using pressureInletOutletVelocity at the top boundary for U. For nut at the ground surface I'm using atmNutUWallFunction.
What do you suggest for the BCs at the top boundary? fixedShearStress?
DJF is offline   Reply With Quote
Old   January 24, 2022, 04:44
Michael Alletto
For a log profile fixedShear is ok. For a Eckman profile a slip condition is ok
Teresa Sun likes this.
boundary layer, k-epsilon, openfoam, turbulent kinetic energy
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 06:25
problems orientating profile Ralf Schmidt FLUENT 1 March 30, 2014 10:00
problem with importing and exporting profile BC Gui CFX 2 July 26, 2007 08:50
Associating profile files for the UDS though a UDF Bharath FLUENT 0 December 1, 2006 15:58
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
