Problem on alphatWallBoilingWallFunction in conjugate heat transfer |
February 9, 2022, 11:36 |
Ching Liu
Rep Power: 8 |
I am simulation boiling heat transfer in a 2D geometry using OenFOAM-v2012. Both the solid and fluid regions are simulated. I used the chtMultiRegionTwoPhaseEulerFoam.
I met a problem on the solid-liquid interface setting. When I used the compressible::turbulentTemperatureTwoPhaseRadCoupl edMixed at the solid-liquid interface. The solver works well. Now I want to use the RPI wall boiling model to simulate the boiling heat transfer. Therefore, I changed the solid-liquid interface to compressible::alphatWallBoilingWallFunction. However, this boundary condition makes the solver not running and no fatal error was shown. Any one has suggestions on the solid-liquid interface setting about RPI wall boiling? |
conjugate heat transfer, rpi wall boiling |
Convergence in a conjugate heat transfer problem | Mohamed Abdulazim | FLUENT | 5 | March 28, 2020 15:41 |
fluent conjugate heat transfer problem | eling | FLUENT | 9 | October 21, 2017 10:10 |
Problem with conjugate heat transfer in Fluent | JianT88 | FLUENT | 0 | March 16, 2015 08:17 |
Transient conjugate heat transfer problem | troyker | FLUENT | 0 | June 21, 2013 03:37 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
