March 2, 2022, 10:33 |
Missing postprocessing probe folder
alex chisholm
Rep Power: 4 |
Hi everyone,
I'm running a simulation for fluid flowing through a channel with cylinders in it using interFlow and i wanted to put a probe inbetween two cylinders. The simulation runs fine with no errors and using paraview the simulation looks similar to what i expected. The issue is that the probe is not producing any data as no postprocessing or probe folders with data are being created. I've attached the controlDict file below. Anyone have any suggestions or common issues that may cause this. I've played around with moving the probe location but that has not fixed it. Code:
#include "../simSetup" tEnd #calc "0.25*$L/$Ul"; writedt #calc "$tEnd/40.0"; dt1 #calc "$Co*$Ry/$nyForRy/$Ul/100.0"; application interFlow; startFrom latestTime; startTime 0; stopAt endTime; endTime $tEnd; deltaT $dt1; writeControl adjustableRunTime; writeInterval $writedt; purgeWrite 0; writeFormat binary; writePrecision 10; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo $Co; maxAlphaCo $Co; maxDeltaT 1; maxCapillaryNum 1000; libs ( "libpostProcess.so" ); functions { freeSurface { type surfaces; libs ("libsampling.so"); writeControl timeStep; // execute the codeWrite every writeInterval time steps writeInterval 100; surfaceFormat raw; fields ( alpha.bubble ); surfaces ( freeSurface { type isoSurfaceCell; isoField alpha.bubble; isoValue 0.5; interpolate false; regularise false; } ); interpolationScheme cellPointFace; } vorticity1 { type vorticity; libs ("libfieldFunctionObjects.so"); writeControl writeTime; } }; probes { functionObjectLibs ( "libsampling.so" ); type probes; // Name of the directory for probe data name probes; writeControl timeStep; writeInterval 10; // Fields to be probed fields ( p U ); probeLocations ( (0 0 0.02) ); } Many thanks |
foamListTimes: How to select latestTime or 0/ folder | petros | OpenFOAM Running, Solving & CFD | 1 | January 28, 2021 07:11 |
how to probe cell volume and probe an entire surface | Andrea23 | OpenFOAM Running, Solving & CFD | 4 | December 11, 2020 11:29 |
PostProcessing folder not updated on convergence | b.simpson | OpenFOAM Post-Processing | 0 | July 23, 2020 09:22 |
fresurface folder in postprocessing folder | shimakasaei | OpenFOAM Post-Processing | 0 | June 14, 2019 11:03 |
How to probe to create time series plot by probe at dialog | POSTHU | Tecplot | 1 | March 21, 2019 08:31 |
