Missing postprocessing probe folder
Old   March 2, 2022, 10:33
Default Missing postprocessing probe folder
alex chisholm
alexc1 is on a distinguished road
Hi everyone,
I'm running a simulation for fluid flowing through a channel with cylinders in it using interFlow and i wanted to put a probe inbetween two cylinders. The simulation runs fine with no errors and using paraview the simulation looks similar to what i expected. The issue is that the probe is not producing any data as no postprocessing or probe folders with data are being created. I've attached the controlDict file below. Anyone have any suggestions or common issues that may cause this. I've played around with moving the probe location but that has not fixed it.
#include "../simSetup"
tEnd #calc "0.25*$L/$Ul";
writedt #calc "$tEnd/40.0";
dt1 #calc "$Co*$Ry/$nyForRy/$Ul/100.0";
application     interFlow;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         $tEnd;
deltaT          $dt1;
writeControl    adjustableRunTime;
writeInterval   $writedt;
purgeWrite      0;
writeFormat     binary;
writePrecision  10;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           $Co;
maxAlphaCo      $Co;
maxDeltaT       1;
maxCapillaryNum 1000;
libs
    "libpostProcess.so"
functions
   freeSurface
       type            surfaces;
       libs            ("libsampling.so");
       writeControl timeStep; // execute the codeWrite every writeInterval time steps
       writeInterval 100;
       surfaceFormat  raw;
       fields
           alpha.bubble
       surfaces
           freeSurface
               type        isoSurfaceCell;
               isoField    alpha.bubble;
               isoValue    0.5;
               interpolate false;
               regularise  false;
       interpolationScheme cellPointFace;
   vorticity1
        type            vorticity;
        libs            ("libfieldFunctionObjects.so");
        writeControl    writeTime;
probes
functionObjectLibs ( "libsampling.so" );
type probes;
// Name of the directory for probe data
name probes;
writeInterval 10;
// Fields to be probed
fields (
	p
	U
probeLocations
(0 0 0.02)
Apologies If i have missed out any key information i am fairly new to openfoam/CFD-online
Many thanks
alexc1 is offline   Reply With Quote
foamListTimes: How to select latestTime or 0/ folder petros OpenFOAM Running, Solving & CFD 1 January 28, 2021 07:11
how to probe cell volume and probe an entire surface Andrea23 OpenFOAM Running, Solving & CFD 4 December 11, 2020 11:29
PostProcessing folder not updated on convergence b.simpson OpenFOAM Post-Processing 0 July 23, 2020 09:22
fresurface folder in postprocessing folder shimakasaei OpenFOAM Post-Processing 0 June 14, 2019 11:03
How to probe to create time series plot by probe at dialog POSTHU Tecplot 1 March 21, 2019 08:31
