The problems about the turbulentDFSEMinlet method for non-reacting jet
Old   April 18, 2019, 12:30
Default The problems about the turbulentDFSEMinlet method for non-reacting jet
lgz
xgyn is on a distinguished road
I have run a non-reacting case with the initial turbulent inlet boundary condition which was created by the turbulentDFSEM method. However, the results there are no velocity fluctuation (u') in the streamline. I don't know how to deal with this problem.
I would appreciate any help on this matter. Thanks in advance! The cases including the files: 0/ were attached.
The turbulentDFSEMinlet was introduced in this website:
https://www.openfoam.com/releases/op...conditions.php
xgyn is offline   Reply With Quote
Old   January 27, 2020, 04:23
Marc
Dreoasteh is on a distinguished road
Maybe it's a bit late but the line:
L        uniform 0;
In your 0/U file defines the lengthscale of your incomming eddies as zero - so there will be no turbulence!
If you used a precursor RANS simulation there are correlations to obtain L from you data. For example for a k-\omega simulation you have that:
L=C_{\nu}^{-1/4}\frac{\sqrt{k}}{\omega}
You can find similar correlations for the model you employed. If you didn't get that data from a precursor RANS, I would suggest looking a two-point correlations to obtain L.
Dreoasteh is offline   Reply With Quote
Old   May 20, 2020, 16:19
Xiangjie Wang
XJ_Wang is on a distinguished road
Hi Marc,
I encountered the same problem.
Could you please give me some suggestions on how to do the RANS precursor simulation?
I set turbulentDFSEMInlet as my inlet velocity.
My computational domain is a wind tunnel with a 50(streamwise)*27.5(width)*22.5(height).
I have run my simulation with a uniform velocity inlet and the results showed that it could work. But when I changed my inlet boundary condition of U, it couldn't.
After inputing blockMesh and decomposePar, I input:
mpirun -np 12 pisoFoam -parallel.
But it was stuck at the first time step, which showed:
Time = 0.005
Courant Number mean: 0 max: 0
In my simulation, the simulation type is RAS, RAS model is KEpsilon.
I only defined the mean velocity profile in ./constant/boundaryData/inlet directory, and for R and L, I set them to a fixed value.
This is how my inlet boundary of U looks like:
inlet
type turbulentDFSEMInlet;
delta 12;
nCellPerEddy 1;
d 1;
R uniform (0.5 0.1 0.1 0.03 0.01 0.01);
L uniform 0.005;
mapMethod nearestCell;
value $internalField;
I will appreciate it if you can give me some suggestions!
Thanks!
Xiangjie
XJ_Wang is offline   Reply With Quote
Old   July 20, 2023, 13:57
Default turbulentDFSEMInlet gets stuck
Alireza Maleki
alireza94 is on a distinguished road
Originally Posted by XJ_Wang View Post
Hi Marc,
Time = 0.005
inlet
delta 12;
nCellPerEddy 1;
d 1;
L uniform 0.005;
Thanks!
Xiangjie
Hi Wang,
It is late, but I have the same problem, it just got stuck in the first iteration and even it does not start making the turbulence and solving the velocity equation.
my simulation is a LES and I gave the R, L, and U, and I'm using the turbulentDFSEMInlet with the following setup
PHP Code:
    inlet
delta           0.0762;   // 0.0762(building width)   typically represents the characteristic scale of flow or flow domain
U
type        mappedFile;
mapMethod   nearest;
R
type        mappedFile;
mapMethod   nearest;
L
type        mappedFile;
mapMethod   nearest;
d               1;
nCellPerEddy    3;   // should be 3 to 5
scale           1;
m                 0.333333333333// 0.3333 lead to a nondimensional c1 in Eq. 11
Another issue is that I'm getting the following warner as well that I don't know the problem of the turbulence generator caused by that or not!
PHP Code:
Reynolds stress (0.50486214 0.50627394 0.61918657 -0.086360121 0.093858697 -0.042078017at index 0 does not obey the constraintRxx*Ryy sqr(Rxy) >=
alireza94 is offline   Reply With Quote
Old   July 20, 2023, 14:35
Xiangjie Wang
Hi Alireza,
I guess you have found out how to solve the problem. You are using an old version of Openfoam, am I right?
Originally Posted by alireza94 View Post
Hi Wang,
PHP Code:
    inlet
U
type        mappedFile;
mapMethod   nearest;
R
type        mappedFile;
mapMethod   nearest;
L
type        mappedFile;
mapMethod   nearest;
d               1;
scale           1;
PHP Code:
Old   July 20, 2023, 15:22
Alireza Maleki
Hi Alireza,
No, indeed I'm using the openFoam 2212, but still I have this problem!
Old   July 20, 2023, 15:24
Xiangjie Wang
Then the Reynold stress tensor might not be correct or pyhsical. You can check the source code and find the corresponding line then you can substitute your reynold tensor to that code.
turbulent boundary
Low temp. (~ 300 K) turb. jet & JANAF problems bart_weisser OpenFOAM Running, Solving & CFD 0 February 11, 2010 18:50
Problems with ansys 12 multizone method jflacerda ANSYS Meshing & Geometry 2 November 19, 2009 11:31
Jet penetration problems Ahmad CFX 6 May 6, 2006 11:51
Solution method for transient problems Roberto Ciardulli Siemens 10 November 28, 2000 04:38
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 16:14
