buoyantSimpleRadiationFoam - "Attempt to return primitive entry [...] mixture [...]"
Old   August 24, 2011, 18:20
Default buoyantSimpleRadiationFoam - "Attempt to return primitive entry [...] mixture [...]"
javad
javad814 is on a distinguished road
hi friends
can anyone understand the fallowing error:
reza@reza-N43SN:~/hotradiationroom1$ buoyantSimpleRadiationFoam
| \\ / O peration | Version: 2.0.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 2.0.0-d79727c3fca7
Exec : buoyantSimpleRadiationFoam
Date : Aug 25 2011
Time : 02:39:31
Host : reza-N43SN
PID : 3479
Case : /home/reza/hotradiationroom1
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
--> FOAM FATAL ERROR:
Attempt to return primitive entry ITstream : /home/reza/hotradiationroom1/constant/thermophysicalProperties::mixture, line 20, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
primitiveEntry 'mixture' comprises
on line 20 the word 'air'
on line 20 the label 1
on line 20 the doubleScalar 28.9
on line 20 the label 1000
on line 20 the label 0
on line 20 the doubleScalar 1.8e-05
on line 20 the doubleScalar 0.7
as a sub-dictionary
From function const dictionary& primitiveEntry::dict() const
in file db/dictionary/primitiveEntry/primitiveEntry.C at line 159.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Foam:rimitiveEntry::dict() const in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#3 Foam::dictionary::subDict(Foam::word const&) const in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 Foam:ureMixture<Foam::constTransport<Foam::speci eThermo<Foam::hConstThermo<Foam:erfectGas> > > >:ureMixture(Foam::dictionary const&, Foam::fvMesh const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
#5 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::hPsiThermo(Foam::fvMesh const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
#7 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantSimpleRadiationFoam"
#9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Aborted
javad814 is offline   Reply With Quote
Old   August 25, 2011, 05:46
Alex
al_pr is on a distinguished road
I think the error is caused by your thermophysicalproperties file. The structure of this file has changed in OpenFOAM 2.0.0. Could you maybe post your thermophysicalproperties?
I hope this helps.
Regards,
Alex
al_pr is offline   Reply With Quote
Old   August 29, 2011, 17:03
javad
hello
thanks
I will check it.
this is the file:
| \\ / O peration | Version: 1.7.0 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
mixture air 1 28.9 1000 0 1.8e-05 0.7;
pRef 100000;
Old   August 30, 2011, 01:29
suh
Suhas
suh is on a distinguished road
Hi Javed,
You are using OF 2.0.0 but you are using the old OF 1.7.1 version file for thermoPhysical model. As an example below is file from OF 2.0.0
FoamFile
version 2.0;
format ascii;
class dictionary;
thermoType hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>;
mixture
specie
nMoles 1;
molWeight 28.9;
thermodynamics
Cp 1007;
Hf 0;
transport
As 1.4792e-06;
Ts 116;
Best luck
Regards
Suhas
suh is offline   Reply With Quote
Old   September 9, 2011, 16:47
javad
thanks alot
Old   November 7, 2017, 11:50
Guillaume
gdum is on a distinguished road
Hi there,
I received the following error.
Can somebody help me to fix it?
Best regards,
Guillaume
| \\ / O peration | Version: 5.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
Build : 5.0-dbb428a3a855
Exec : simpleReactingParcelFoam
Date : Nov 07 2017
Time : 10:25:39
Host : "guillaume-VirtualBox"
PID : 17846
I/O : uncollated
Case : /home/guillaume/OpenFOAM/FM_in_duct
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
SIMPLE: convergence criteria
field p tolerance 0.001
field U tolerance 0.0001
field "(k|epsilon|air|H2O)" tolerance 0.0001
Reading g
Creating combustion model
Selecting combustion model noCombustion<rhoThermoCombustion>
type heRhoThermo;
mixture reactingMixture;
transport polynomial;
thermo hPolynomial;
energy sensibleEnthalpy;
equationOfState icoPolynomial;
specie specie;
Selecting chemistryReader foamChemistryReader
elements not defined in "/home/guillaume/OpenFOAM/FM_in_duct/constant/reactions"
Creating component thermo properties:
multi-component carrier - 2 species
liquids - 1 components
solids - 0 components
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model realizableKE
RAS
turbulence on;
RASModel realizableKE;
printCoeffs on;
A0 4;
C2 1.9;
sigmak 1;
sigmaEps 1.2;
Creating multi-variate interpolation scheme
No MRF models present
Selecting radiationModel none
Constructing reacting cloud
Constructing particle forces
Selecting particle force sphereDrag
Selecting particle force gravity
Constructing cloud functions
none
Constructing particle injection models
Creating injector: model1
Selecting injection model coneInjection
Constructing 3-D injection
Selecting distribution model RosinRammler
Creating injector: dispersionModel
Attempt to return primitive entry ITstream : /home/guillaume/OpenFOAM/FM_in_duct/constant/reactingCloud1Properties.subModels.injectionModels .dispersionModel, line 122, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
primitiveEntry 'dispersionModel' comprises
on line 122 the word 'none'
as a sub-dictionary
From function virtual const Foam::dictionary& Foam:rimitiveEntry::dict() const
in file db/dictionary/primitiveEntry/primitiveEntry.C at line 189.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam:rimitiveEntry::dict() const at primitiveEntry.C:?
#3 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleReactingParcelFoam"
#4 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleReactingParcelFoam"
#5 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleReactingParcelFoam"
#6 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleReactingParcelFoam"
#7 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleReactingParcelFoam"
#8 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleReactingParcelFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleReactingParcelFoam"
Aborted (core dumped)
gdum is offline   Reply With Quote
Old   June 14, 2022, 00:57
Default Foam Fatal error
Ovais
aqibovais is on a distinguished road
--> FOAM Warning :
From function bool Foam::functionObjectList::read()
in file db/functionObjects/functionObjectList/functionObjectList.C at line 744
Caught FatalError
Attempt to return primitive entry ITstream : F:/Workspace/Ovais/KNPCC/3D-Nozzle-Drawing/Run/V1/system/controlDict.functions.streamLines.seedSampleSet, line 82, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
primitiveEntry 'seedSampleSet' comprises
on line 82 the word 'uniform'
as a sub-dictionary
Please anyone help me...
aqibovais is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[snappyHexMesh] castellatedMeshControls seems to be undefined reza1980 OpenFOAM Meshing & Mesh Conversion 26 March 14, 2019 00:55
Creating a new field from terms of the turbulence model HaZe OpenFOAM Programming & Development 15 November 24, 2014 13:51
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
