Turbulent flow around a 2D Cylinder
Old   July 9, 2022, 13:06
Default Turbulent flow around a 2D Cylinder
Alessio Piccolo
Ale22pic is on a distinguished road
Hi everybody, I'm trying to replicate, in OpenFOAM, a case in the paper "A low-dissipative solver for turbulent compressible flows on unstructured meshes, with OpenFOAM implementation" by Davide Modesti and Sergio Pirozzoli. Anyway I attach the link to my GitHub repository:
https://github.com/Ale22pic/REFV2006...in/CylinderRAS
I'm doing a RANS simulation with Spalart model.
The solver that I use is rhoEnergyFoam, which is a solver which we implemented in OpenFOAM. The problem is that I'm arguing with the boundary condition since I'm using an O-grid mesh (where the cylinder diameter is 1 and the domain diameter is 40) since after a lot timestep the solution is still not stationary and the pressure coefficient on the cylinder is not constant in time. Could you please check my case and tell me where are the mistakes?
Thank you so much,
Alessio
Ale22pic is offline   Reply With Quote
Turbulent flow over a circular cylinder? ck3 FLUENT 6 May 4, 2018 12:20
k-omega SST simulation of turbulent flow around a circular cylinder DanM OpenFOAM Running, Solving & CFD 17 October 13, 2016 13:29
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
Flow over 2D Cylinder, Laminar and Turbulent Tsr63 FLUENT 5 November 13, 2014 12:13
Compare the pressure of potential flow and a turbulent case of cylinder ooo OpenFOAM Running, Solving & CFD 0 August 2, 2013 07:25
