SimpleFoam Simulation for windtunnel is not converging
Old   July 18, 2022, 10:47
Unhappy SimpleFoam Simulation for windtunnel is not converging
Wanting
Wanting is on a distinguished road
Dear all,
I am simulating the wind flow in a wind tunnel where a cube obstacle is presented. Since I am only interested in the steady state, I am using SimpleFoam for the simulation. However, by monitoring the residual, it seems the simulation is not converged. And also by looking into the results for different iterations, the results are also different.
It seems a relatively simple case since my object has a very simple shape and the wind tunnel is also standard. However, I have tried everything I can think of for several weeks and it is still not working. I will really appreciate it if you could have a look.
The working dictionary and the plot of the residual are attached. Thanks a lot for your help!
Best,
Wanting
Wanting is offline   Reply With Quote
Old   July 22, 2022, 05:14
N/A
twnspl is on a distinguished road
Please check quantities like velocity or pressure to see if the simulation is converged or not in addition to using the residuals.
twnspl is offline   Reply With Quote
Old   July 29, 2022, 11:08
Josh Williams
joshwilliams is on a distinguished road
Yes flow around a cube is a very simple case, where obviously a cube is a simple geometry. But flow around bluff bodies like a cube is notoriously complex and transient (e.g. von Karmaan vortex streets). Also, as there is a clear fluctuation in your residuals, this seems that you have an oscillating flow. I would recommend switching to a transient solver (pimpleFoam, pisoFoam, etc) and performing time-averaging of the flow to extract whatever your quantity of interest is.
joshwilliams is offline   Reply With Quote
cube, openfoam 9, simplefoam, wind tunnel simulation
Moment monitor not converging in transient simulation saikath65 FLUENT 0 August 21, 2020 08:58
Although having reduced the time step, the simulation is not converging HectorRedal Main CFD Forum 41 February 8, 2017 20:16
Simulation not converging (core dumped) jet_engine OpenFOAM Running, Solving & CFD 2 May 25, 2016 08:31
Flat Plate: Simulation is not converging Luana.M. OpenFOAM Running, Solving & CFD 1 April 14, 2016 01:14
Dynamic mesh simulation not converging mrestrepo30 FLUENT 0 March 8, 2010 14:15
