Lagrangian particles adddition to interFoam using swak4Foam |
August 19, 2022, 04:43 |
Baba
I am trying to simulate rising of bubble in a solid-liquid suspension. For the bubble-liquid interface interFoam solver is used. Particle addition is carried out by swak4Foam. But when I am running the simulations, I am getting a warning like "No entry 'dimension' in field muField". However I am able to complete the simulations. Should I do something? Please help. Thanks in advance, Baba |
August 20, 2022, 07:34 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
No. swak turns of dimension checking for its calculations because that would complicate things for the user (for instance: half of the numeric constants people use in expressions would need to have to have dimensions added to them. Otherwise dimension checking when adding them to a field that is not dimensionless would fail). Of course that disables one of the cool (and for the novice user annoying) features of OF: dimension checking. swak4Foam assumes that the user did the dimension checking of his expressions by hand The expressionField function object allows the user to specify a dimension for the result post-calculation because sometimes it is used to "mock" the existence of a field for a boundary condition etc that checks for that dimension. Also: it is good practice to add that dimension to document "I checked the dimension: this is it". I rarely do this. But this only proofs what I always say "Just because I wrote swak4Foam doesn't mean that I use it properly"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
August 23, 2022, 01:45 |
Baba
Thank you very much for your response.
Sincerely, Baba |
interfoam bubble, lagrangian particles, swak4foam |
Radiation heating of lagrangian particles in reactingParcelFoam | CHUIKOV | OpenFOAM Running, Solving & CFD | 0 | February 28, 2021 14:53 |
Lagrangian Particles + Porosity | 37269 | OpenFOAM Running, Solving & CFD | 3 | September 25, 2020 04:14 |
Lagrangian particles injection with interFoam and swak4foam | Cluap | OpenFOAM Running, Solving & CFD | 0 | June 12, 2018 11:37 |
Lagrangian Data extract from sprayFoam e.g. with swak4Foam | mokard | OpenFOAM Post-Processing | 2 | January 16, 2018 03:44 |
Corellation dimension of lagrangian particles | oswald | OpenFOAM Post-Processing | 0 | January 27, 2016 07:30 |
