How to output the drag force on particle in LPT OpenFoam
Old   April 17, 2018, 17:38
Default How to output the drag force on particle in LPT OpenFoam
Jingchang.Shi
aerosjc is on a distinguished road
I use OpenFoam to simulate one particle in fluid. I used the “Spheredrag” and I would like to output the drag force on the particle. First I added some codes in the SphereDragForce.C, which is in /lagrangian/intermediate/submodels/Kinematic/ParticleForces/Drag/SphereDrag
The following is the code and the red lines are that I added by myself.
#include "SphereDragForce.H"
#include <iostream>
#include <fstream>
// * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
template<class CloudType>
Foam::scalar Foam::SphereDragForce<CloudType>::CdRe(const scalar Re) const
    if (Re > 1000.0)
        return 0.424*Re;
    else
        return 24.0*(1.0 + 1.0/6.0*pow(Re, 2.0/3.0));
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::SphereDragForce<CloudType>::SphereDragForce
    CloudType& owner,
    const fvMesh& mesh,
    const dictionary& dict
    ParticleForce<CloudType>(owner, mesh, dict, typeName, false)
    const SphereDragForce<CloudType>& df
    ParticleForce<CloudType>(df)
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::SphereDragForce<CloudType>::~SphereDragForce()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
ofstream outputfile1("dragforce.dat", std::ios::out );
Foam::forceSuSp Foam::SphereDragForce<CloudType>::calcCoupled
    const typename CloudType::parcelType& p,
    const scalar dt,
    const scalar mass,
    const scalar Re,
    const scalar muc
) const
    forceSuSp value(Zero, 0.0);
    value.Sp() = mass*0.75*muc*CdRe(Re)/(p.rho()*sqr(p.d()));
	outputfile1 << "drag " << value.Sp()  << endl;
	return value;
When I do wmake libso, the following errors appear:
Make/linux64GccDPInt32Opt/parcels/derived/basicThermoParcel/makeBasicThermoParcelSubmodels.o:(.bss+0xb80): multiple definition of `outputfile1'
Make/linux64GccDPInt32Opt/parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.o:(.bss+0xb40): first defined here
Make/linux64GccDPInt32Opt/parcels/derived/basicReactingParcel/makeBasicReactingParcelSubmodels.o:(.bss+0xd00): multiple definition of `outputfile1'
Make/linux64GccDPInt32Opt/parcels/derived/basicReactingMultiphaseParcel/makeBasicReactingMultiphaseParcelSubmodels.o:(.bss+0xec0): multiple definition of `outputfile1'
Make/linux64GccDPInt32Opt/parcels/derived/basicKinematicMPPICParcel/makeBasicKinematicMPPICParcelSubmodels.o:(.bss+0xdc0): multiple definition of `outputfile1'
collect2: error: ld returned 1 exit status
make: *** […/platforms/linux64GccDPInt32Opt/lib/libZHOnelagrangianIntermediate.so] Error 1
So I think maybe we cannot add the codes in SphereDragForce.C to output the drag force on particle. Then I added some codes (red color) in the creatFields.H and here are the codes:
#include "readGravitationalAcceleration.H"
word continuousPhaseName
    IOdictionary
        IOobject
            "transportProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ
    ).lookup("continuousPhaseName")
Info<< "Reading field U\n" << endl;
volVectorField Uc
    IOobject
        IOobject::groupName("U", continuousPhaseName),
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
Info<< "Reading field p\n" << endl;
volScalarField p
    IOobject
        "p",
        runTime.timeName(),
        mesh,
    mesh
Info<< "Reading/calculating continuous-phase face flux field phic\n"
    << endl;
surfaceScalarField phic
    IOobject
        IOobject::groupName("phi", continuousPhaseName),
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT,
    linearInterpolate(Uc) & mesh.Sf()
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, pimple.dict(), pRefCell, pRefValue);
mesh.setFluxRequired(p.name());
Info<< "Creating turbulence model\n" << endl;
singlePhaseTransportModel continuousPhaseTransport(Uc, phic);
dimensionedScalar rhocValue
    IOobject::groupName("rho", continuousPhaseName),
    dimDensity,
    continuousPhaseTransport.lookup
volScalarField rhoc
    IOobject
        rhocValue.name(),
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    mesh,
    rhocValue
volScalarField muc
    IOobject
        IOobject::groupName("mu", continuousPhaseName),
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    rhoc*continuousPhaseTransport.nu()
Info << "Creating field alphac\n" << endl;
// alphac must be constructed before the cloud
// so that the drag-models can find it
volScalarField alphac
    IOobject
        IOobject::groupName("alpha", continuousPhaseName),
        runTime.timeName(),
        mesh,
    mesh,
    dimensionedScalar("0", dimless, 0)
word kinematicCloudName("kinematicCloud");
args.optionReadIfPresent("cloudName", kinematicCloudName);
volScalarField spheredrag
IOobject
"SphereDragForce",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh,
Info<< "Constructing kinematicCloud " << kinematicCloudName << endl;
basicKinematicTypeCloud kinematicCloud
    kinematicCloudName,
    rhoc,
    Uc,
    muc,
    g
// Particle fraction upper limit
scalar alphacMin
    1.0
  - readScalar
        kinematicCloud.particleProperties().subDict("constantProperties")
       .lookup("alphaMax")
// Update alphac from the particle locations
alphac = max(1.0 - kinematicCloud.theta(), alphacMin);
alphac.correctBoundaryConditions();
surfaceScalarField alphacf("alphacf", fvc::interpolate(alphac));
surfaceScalarField alphaPhic("alphaPhic", alphacf*phic);
autoPtr<PhaseIncompressibleTurbulenceModel<singlePhaseTransportModel>>
continuousPhaseTurbulence
    PhaseIncompressibleTurbulenceModel<singlePhaseTransportModel>::New
        alphac,
        Uc,
        alphaPhic,
        phic,
When I run wmake, it compile successfully.
But when simulate a case, it shows the error
cannot find file "…/0/SphereDragForce"
From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file
global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 505.
FOAM exiting
Thanks
aerosjc is offline   Reply With Quote
Old   January 2, 2020, 03:20
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
Did you find out how to print the drag force on the particle?
saiguruprasad is offline   Reply With Quote
Old   November 17, 2022, 09:49
Shah Akib Sarwar
Shah Akib Sarwar is on a distinguished road
Did any of you find a solution to this? I am trying to do the same thing, but cannot figure out how.
Shah Akib Sarwar is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
What variable should I output to get wall force? Pauli CFX 6 May 15, 2018 07:58
How to give Buoyancy and drag force for a particle in dpm krishna.n FLUENT 3 May 24, 2016 02:31
particles leave domain Steffen595 CFX 9 March 7, 2016 16:19
Particle Velocity in presence of magnetic force and drag force hamed1206 Electromagnetics 0 January 10, 2016 02:51
