Error messages when running on HB120rs v3
Old   January 11, 2023, 08:05
Default Error messages when running on HB120rs v3
Mohamed Mousa
Mohamed Mousa is on a distinguished road
Hello everyone,
I am getting those annoying messages before the header when I run OpenFOAM on a Standard HB120rs v3 (120 vcpus, 448 GiB memory) machine on Microsoft Azure. it's an AMD Epyc machine.
I noticed that I don't get these lines when I choose an Intel machine.
Can anyone help me explaining what are these lines are trying to tell me?
[hps:03989] [[64250,0],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file util/show_help.c at line 507
WARNING: No preset parameters were found for the device that Open MPI
detected:
  Local host:            hps
  Device name:           mlx5_0
  Device vendor ID:      0x02c9
  Device vendor part ID: 4124
Default device parameters will be used, which may result in lower
performance.  You can edit any of the files specified by the
btl_openib_device_param_files MCA parameter to set values for your
device.
NOTE: You can turn off this warning by setting the MCA parameter
      btl_openib_warn_no_device_params_found to 0.
By default, for Open MPI 4.0 and later, infiniband ports on a device
are not used by default.  The intent is to use UCX for these devices.
You can override this policy by setting the btl_openib_allow_ib MCA parameter
to true.
  Local host:              hps
  Local adapter:           mlx5_0
  Local port:              1
WARNING: There was an error initializing an OpenFabrics device.
  Local host:   hps
  Local device: mlx5_0
Open MPI failed an OFI Libfabric library call (fi_endpoint).  This is highly
unusual; your job may behave unpredictably (and/or abort) after this.
  Local host: hps
  Error: Unspecified error (256)
|  \\    /   O peration     | Version:  2212                                  |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : _fd8c5e00-20221221 OPENFOAM=2212 version=2212
Thanks in advance
Regards,
Mohamed Mousa is offline   Reply With Quote
Simulation just stops output writing, but keeps running blaise OpenFOAM Running, Solving & CFD 6 March 27, 2024 05:49
Running Case in Parallel Typ Main CFD Forum 5 May 11, 2020 04:43
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 04:38
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 16:01
