OpenFOAM - Quick way to delete previous calculation & HowTo get access to variables |
April 19, 2010, 11:18 |
Christoph
Rep Power: 16 |
Hi!
Is there a quick way to delete all previous timesteps in a calculation (e.g. a script, deleting all directories regarding the time-steps w/o the "0" directory)? plus: how can I tell the solver which variables to write to the result file - using buoyantBoussinesqPisoFoam I would like to have access to e.g. k and eps for post-processing. Regards, Kriz |
April 19, 2010, 12:18 |
Eelco van Vliet
Rep Power: 19 |
Hi Kriz,
Just install pyFoam, a great set of python utilities by Bernhard Gschaider for doing all kind of openfoam tasks. Have a look at http://openfoamwiki.net/index.php/Contrib_PyFoam For clearing your case directory, it would become one single command: pyFoamClearCase.pl . Regards, Eelco |
April 19, 2010, 13:02 |
#3 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
It's not an uncommon task. I usually use http://openfoamwiki.net/index.php/Co...amClearCase.py for that (but usually every computer I touch becomes polluted with that stuff, so this is the easiest thing to do for ME, not necessarily for everyone) Quote:
Just curious: are you sure you're using a turbulence model that HAS k/epsilon (because usually such a turbulence model writes these out) Bernhard |
February 14, 2018, 18:16 |
Katsantonis Michalis
Rep Power: 8 |
There is a command included in OpenFOAM that lists all of the time directories, you just just have to type > foamListTimes.
Now, if you want to remove all those directories, you type > foamListTimes -rm |
February 15, 2018, 00:27 |
Uwe Pilz
Rep Power: 15 |
mv 0 O rm -r 0* rm -r 1* rm -r 2* rm -r 3* rm -r 4* rm -r 5* rm -r 6* rm -r 7* rm -r 8* rm -r 9* mv O 0 rm -r postProcessing
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
February 15, 2018, 09:33 |
Robert
Rep Power: 11 |
Or shorter
rm -r 0.* [1-9]* |
February 15, 2018, 10:30 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Which can be problematic for some of the tutorial-cases that have a 0.orig-directory
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 31, 2019, 02:59 |
Carlo_P
Rep Power: 7 |
Hey guys,
if you need, it is possible to use the command "foamCleanTutorials". It is very usefull command to clean the directory. Cheers, Carlo |
July 23, 2021, 07:32 |
#9 |
Yugal Sharma
Rep Power: 5 |
July 23, 2021, 07:39 |
#10 | |
Yugal Sharma
Rep Power: 5 |
So you have to again do the meshing stuff (i.e.- blockMesh). Basically, the foamCleanTutorial command makes your case's folder contain only the 0/, constant/, system/ directories. (and maybe someother files), more like a fresh case folder. |
September 1, 2021, 02:23 |
decomposed
#11 | |
Yanjun Tong
Rep Power: 5 |
rm -rf processor*/[time] or rm -rf processor* to delete all processors |
September 1, 2021, 09:42 |
#12 |
Yann
Rep Power: 26 |
For decomposed cases, you can also use foamListTimes with the processor option:
foamListTimes -processor -rm Cheers, Yann |
March 6, 2023, 03:20 |
#13 |
Karthik Lukka
Vielen Danke.
The calculation efficiency of OpenFOAM | chiven | OpenFOAM Running, Solving & CFD | 4 | September 14, 2009 04:44 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix | mbeaudoin | OpenFOAM Installation | 2 | April 28, 2006 08:54 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
access to variables at interface of porous media? | Mazyar | FLUENT | 0 | October 10, 2003 14:59 |
