[Sponsors] | |||||
Rep Power: 5 ![]() |
Dear all,
I am doing simulation for NH3/H2/air combustion using OpenFOAM-8 (Foundation ver.) with reactingFoam solver. There is no run time error detected, however I failed to achieve sustainable flame. The boundary condition is based on successful experiment [1] so I don't think that specifying fuel/oxidizer composition beyond NH3/H2 flammability range is causing this ignition failure. I also conducted similar simulation by adding NH3 on steady H2 combustion with same chemical mechanism proposed by Okafor at al. [2] The generated flame is sustainable which indicated by steady consumption of NH3. From this observation, I deduce that the problem lies on numerical side specifically mesh. I need to get the flame ignited in my simulation so I could validate the results with experimental data. Any help would be greatly appreciated. Attached with this message are: 1) Animation of failed ignition simulation 2) Animation of sustainable flame (different mesh) 3) Case that could be used to reproduce the failed ignition. Already tested for both series and parallel run. NH3-TNF.zip Failed_H2-NH3-O2.zip sus-flame_H2-NH3-O2.zip Regards, Waluyo Refereces: [1] Tang, H., Yang, C., Wang, G., Krishna, Y., Guiberti, T. F., Roberts, W. L., & Magnotti, G. (2022). Scalar structure in turbulent non-premixed NH3/H2/N2 jet flames at elevated pressure using Raman spectroscopy. Combustion and Flame, 244. [2] Okafor, E. C., Naito, Y., Colson, S., Ichikawa, A., Kudo, T., Hayakawa, A., & Kobayashi, H. (2018). Experimental and numerical study of the laminar burning velocity of CH4–NH3–air premixed flames. Combustion and Flame, 187, 185–198. https://doi.org/10.1016/j.combustflame.2017.09.002 |
mingyang
Rep Power: 4 ![]() |
As far as I know, OpenFOAM-8 is a physical property file without NH3, is it a problem for you to write the file yourself? Please upload the NH3 file to me for a look.
Dear Yang,
Thank you for your reply, I really appreciate it. In OpenFOAM-8, reacting flow simulation is supported by using reactingFoam solver. I have uploaded the case (NH3-TNF.zip), which contains initial and boundary conditions of chemical species, including NH3 in 0.orig/NH3. In case you want to check on NH3 file directly, I will attach it here: NH3.txt The information regarding thermophysical properties of individual species can be found in constant/foam_mech/modGRI.fmth The information regarding chemical reactions in this simulation can be found in constant/foam_mech/modGRI.fmr Thank you for checking my case. Best regards, Waluyo |
Hafiz Ahmad
Rep Power: 8 ![]() |
Hi RWaluyo, did you manage to fix your issue? I am simulating the similar case and have failed to achieve a sustainable flame.
No, I have not been able to do it.
Perhaps I need to stop. |
anonymous.
Hi, I can simulate the CAJF14 flame with stable state using OpenFOAM-10 and Zhang mechanism(10.1016/j.combustflame.2021.111653) and laminar model. I think there are 2 possibilities of failure.
1. The OpenFOAM-8 may use the unity Lewis number assumption for species diffusion, each species has equal diffusivity. This can significant influence the extinction limits of CAJF14 flame and CAJF28 flame. You can try OpenFOAM-10, it contains the differential diffusion model(see FickianEddyDiffusivity.H). 2. You can try lamianr model. The PaSR model uses a factor smaller than 1 to scale the reaction rate, This is not friendly with stable flame. 3. Maybe you can simulate CAJF28 first, after reaching stable state, you can change the boundary condition of composition |
Thank you very much for replying to my question zd7s18533.
However, I currently do not have the resource to confirm stability of CAJF28 flame using high-fidelity technique such as LES. I am trying to simulate NH3 flame using axisymmetric RANS simulation. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ignition and flame propagation with XiFoam for a few meters long comput. domains | Gloq | OpenFOAM Running, Solving & CFD | 1 | February 21, 2023 13:22 |
| Ignition source modelling in CONVERGE | JVJ | CONVERGE | 5 | March 4, 2020 08:09 |
| Simulate an ignition point in dieselEngineFoam ? | paladin | OpenFOAM Running, Solving & CFD | 0 | July 30, 2012 11:14 |
| how does the ignition model initiate main combustion | mepgzzi | Siemens | 0 | June 23, 2012 15:32 |
| Ignition modeling | Julie Polyakh | Siemens | 0 | May 20, 2004 09:05 |
