Porus Media simulation with ANSA pre-processor |
HR
Rep Power: 3 ![]() |
Hello all,
I am trying to simulate flow through a metal woven screen as shown in the attached image. I use ANSA for mesh generation. How do I simulate this using porusSimpleFoam ? I understand that I have to define cell zones where the porous media exists. However I do not know how to do this in ANSA. If anyone has attempted this type of simulation before, please share the workflow that you use. |
cellZones in OpenFOAM are different solid PIDs in ANSA (I think ANSA calls volume PIDs solids by default). So you need to create different volumes in ANSA, where your porous medium gets a PID assigned to it called porous and the other volume/volumes are called fluid for instance. Then just export normally. I think you can even setup the porous medium completely in ANSA with all the files outputted along with your mesh, but I usually just copy these kind of files from another (old) case. Good luck, Tom |
#3 | |
HR
Personally I adjust the OpenFOAM text files, but that is a matter of preference. You can try the preprocessor, but I have no experience on it. Cheers, Tom |
Foam-Extend 4.0 simpleFoam motorbike parallel error? | EternalSeekerX | OpenFOAM Running, Solving & CFD | 0 | May 10, 2021 04:55 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
