Porus Media simulation with ANSA pre-processor
Like Tree1Likes
  • 1 Post By tomf
Old   March 24, 2023, 03:45
Default Porus Media simulation with ANSA pre-processor
HR
hr_nt is on a distinguished road
Hello all,
I am trying to simulate flow through a metal woven screen as shown in the attached image. I use ANSA for mesh generation. How do I simulate this using porusSimpleFoam ? I understand that I have to define cell zones where the porous media exists. However I do not know how to do this in ANSA. If anyone has attempted this type of simulation before, please share the workflow that you use.
hr_nt is offline   Reply With Quote
Old   March 25, 2023, 07:18
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
cellZones in OpenFOAM are different solid PIDs in ANSA (I think ANSA calls volume PIDs solids by default). So you need to create different volumes in ANSA, where your porous medium gets a PID assigned to it called porous and the other volume/volumes are called fluid for instance.
Then just export normally. I think you can even setup the porous medium completely in ANSA with all the files outputted along with your mesh, but I usually just copy these kind of files from another (old) case.
Good luck,
Tom
rmaries likes this.
tomf is offline   Reply With Quote
Old   March 26, 2023, 23:42
HR
Originally Posted by tomf View Post
Good luck,
Tom
Thank you for the response, I think I forgot to select the volumes as porous in ANSA. I will check it out, do you assign the darcy and forcheimer coefficients in the pre-processor or do you assign it seperatly in the porosityProperties file ?
Old   March 27, 2023, 04:40
Tom Fahner
Personally I adjust the OpenFOAM text files, but that is a matter of preference. You can try the preprocessor, but I have no experience on it.
Cheers,
Tom
Foam-Extend 4.0 simpleFoam motorbike parallel error? EternalSeekerX OpenFOAM Running, Solving & CFD 0 May 10, 2021 04:55
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
