Extract angular velocity, momentum & wake properties |
September 28, 2023, 19:40 |
JMRS
Rep Power: 2 |
Hi! I'm new to openFoam & I'm beginning to learn programming in C++.
I have a simulation of a wind turbine inmersed in a flow where the wind moves the turbine so I have variable angular velocity & wake properties. I use the sixDoFRigidBodyMotion in the DynamicMeshDict and when the simulation runs it writes the angular velocity and angular momentum computed. My question is, How do I extract the angular velocity so that the program writes it? And my other question is, How can I extract the wake properties? Or do I have to do it in Paraview? Greetings to all |
September 29, 2023, 02:36 |
Jan
Rep Power: 19 |
https://www.openfoam.com/news/main-n...ost-processing I never used, but maybe does already what you need without extra programming. Or at least serves as a good starting point. Best, Jan |
October 12, 2023, 16:57 |
JMRS
Rep Power: 2 |
Thank you!
angularvelocity |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 457 | March 27, 2024 00:59 |
How can i extract the angular velocity value using the dynamic Mesh tool fluent | AbdelFree02 | FLUENT | 0 | July 21, 2023 15:43 |
Extract velocity from probes at every timestep to be used in Macro | howarceus | STAR-CCM+ | 2 | April 19, 2023 15:19 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
